I can no longer import my models, or MCMaster?
JoshBrowne89
JoshBrowne89
I have done this a million times.  The Tree shows that I have imported a model from either my own library or McMaster but it stays hidden no matter what.  I've tried closing the assembly model, as well as updating and restarting the whole program.
Seems like f360 has just been going downhill every time I use it now...
RajkumarIlanchelian
@JoshBrowne89 @When you say it stays hidden are you not able to see it in the data panel? Are you referencing another design I to your assembly and you are not seeing it ? Can you add some pictures or perhaps a video showing what you are seeing?
also you mentioned Fusion is going downhill every time you use it , what are some of the other issues you are facing?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
