- Mute
- Permalink
- Report
I run into an odd issue today. When I tried to change one of the user defined properties nothing changed in the model. I've inspected the sketch where the dimension is used and it was marked as red. When I delete it I can drag the line without any issues whatsoever, ie. I can resize the dimension Fusion 360 marked as red. When I try to specify a dimension with a different value than what I set by dragging I get the "failed to solve" error. I attach a screencast. Unfortunately I can't attach the file.
