I am very much a beginner so this may be obvious - rotating object 90 degrees around component
mitchel.greer
Message 1 of 8
mitchel.greer
first project. logo plate on wrong facelogo plate on wrong face
I only need one logo plate so the circular pattern isn't desirable and it's the only way I know how to do it easily. Is there any efficient way to do it?  also, any tips/suggestions for overall design would be appreciated.
Replies (7)
Message 2 of 8
seth.madore
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 8
mitchel.greer
Thanks for the reply! Here you go
Message 4 of 8
seth.madore
Are you referring to these Bodies?
 And the goal is to just rotate them 90 degrees around?
Seth Madore
Message 5 of 8
mitchel.greer
yes should of been more specific
Message 6 of 8
seth.madore
There's a bunch of ways to do it, here's one:
Seth Madore
Message 7 of 8
mitchel.greer
Thanks!
Message 8 of 8
g-andresen
try  „suppress option“ inside circular pattern
günther
