How to subtract / cut from a mesh?
SimonPlatten
Message 1 of 18
SimonPlatten
I have a mesh, I would like to subtract / cut an object from the mesh, but how?
Replies (17)
Message 2 of 18
paul.clauss
Hi @SimonPlatten
Thanks for posting and welcome to the Fusion 360 community! To subtract or cut away from a mesh, you can use either the "Plane Cut" or "Separate" tools in the Mesh workspace. I have shown a brief example of this in the screencast below.
You could always convert the mesh to a solid body and then use the split bodies tool to edit the model as well - if your desired final format is a mesh, you could convert the mesh to a solid, make the desired model changes, and then save the edited body as an STL.
Hopefully this helps! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Message 3 of 18
SimonPlatten
Thank you, I tried converting the mesh to an object, but it failed Triangles  = 42735.
Message 4 of 18
paul.clauss
Hi @SimonPlatten
Thanks for the response! You will need to Reduce the mesh to convert it, as shown briefly in my video. There is a limit to how many triangles can be converted from a mesh to solid.
Paul Clauss
Message 5 of 18
SimonPlatten
I've tried to do this and I get an error, which isn't very helpful because it simply says "Reduce failed due to invalid input"
The settings in the dialog are:
Mesh Faces / Body:   1 Selected
Reduce Type: Adaptive
Reduce Target: Density
I've tried various options but all result in the same.
Message 6 of 18
paul.clauss
Hi @SimonPlatten
Thanks. Would you mind sharing the mesh file you are working with me? I'm happy to have a look.
Paul Clauss
Message 7 of 18
SimonPlatten
No problem, only problem is I have no idea where on my iMAC the project files are located, if you can tell me I will attach the model.
The original model is not my work, I download the STL file and imported into Fusion 360, then split the mesh into multiple parts for printing.
Message 8 of 18
paul.clauss
Sharing a Fusion 360 design - or feel free to attach the downloaded STL file to your next post.
Paul Clauss
Message 9 of 18
SimonPlatten
Ok, thank you, that doesn't really help though because although I've created the archive, I still have no idea where to find it.
Message 10 of 18
SimonPlatten
Sorry for double post, I got an error when trying to post the initial reply.
Message 11 of 18
paul.clauss
Hi @SimonPlatten
When you create the export, the dialogue box shows a flag to "Save to my computer," and then the filepath the local copy will be saved at. You can change this location by clicking the ellipses in the box to the right of the filepath.localsave.png
Paul Clauss
Message 12 of 18
SimonPlatten
Its so frustrating, the file dialog only shows the end folder called "files", but I have no idea where it is in my profile.
Message 13 of 18
paul.clauss
Hi @SimonPlatten
Thanks. Clicking the ellipse should take you to the folder the file was exported to in Windows File Explorer/ Mac Finder. You also always export another copy to any location by clicking the ellipses to change the output location.
Paul Clauss
Message 14 of 18
SimonPlatten
I think I have it....Attached is the project.
Message 15 of 18
paul.clauss
Hi @SimonPlatten
Thanks for attaching the file. I think the issue with being unable to reduce the mesh was due to a small hole somewhere - I was able to reduce after making a closed mesh. I have shown this in the screencast below.
It does look like you were able to split the mesh into four parts successfully, so you may be able to keep more detail in the model by converting the four sections of the model individually. Depending on what you are trying to do with this model, you may not even need to convert it. If you just want to remove areas, I would recommend keeping a mesh this large in mesh form and then using the methods described in my previous screencast - my recommendation would be to split off the base, as it would be easy to recreate as a much simpler solid body. This would be easy to do with a plane cut, as shown in the GIF below:
I also found that the mesh contains some internal geometry - deleting this geometry (as it is not visible from the exterior), may also help keep the detail in this design while reducing it.
Paul Clauss
Message 16 of 18
SimonPlatten
Thank you, I'm very new to Fusion 360, I have a lot to learn.
Message 17 of 18
SimonPlatten
Out of the meshes, I can't reduce these:
FrontRightTop
FrontRightBottom
FrontLeftTop
All the others have been successfully reduced, how do I go about finding the problem?
Edit....actually I think I've found the solution, Select problem mesh, Make Closed Mesh, then reduce and this works.
Thanks again!
Message 18 of 18
autodesk5K59U
Community Visitor
Community Visitor
Paul - 7 years later and you helped me today! The video is still helpful despite the UI changes... I wish all product support teams were this helpful. Thanks!
