How to shorten an object after design it and how to increase pipe size inside an object after design
memo2022
Message 1 of 9
memo2022
hi guys, how to shorten an object size after design and how to increase the tube size inside an object  after designing it. If possible to make a vdieo, it would be so helpful and appreciated thanks
Replies (8)
Message 2 of 9
davebYYPCU
Change length of article,
Edit Feature (that created it) change the value in the box that needs to change.
Change the diameter, same, Edit Feature, Change value.
No file to test, best guess.
Might help...
Message 3 of 9
TheCADWhisperer
@memo2022
I would use Edit commands.
Message 4 of 9
memo2022
Thanks. I attached the file. I want to shorten the object without using the edit feature please. Thanks
Message 5 of 9
jeff_strater
"I want to shorten the object without using the edit feature please"
Why?  This is, in fact, the entire reason why parametric CAD design exists - so you can easily modify your design.
However, if you really want to do this, use Offset Faces.  You don't say which end you want to shorten, so I picked the smaller end.  You can use this on either end, though.:
Jeff Strater
Engineering Director
Message 6 of 9
davebYYPCU
Some interesting things here.
3 surface bodies from one extrude. (3 circles)
Changing diameter without edit sketch.  Use Press Pull, (Yuk)
Might help...
Message 7 of 9
memo2022
Sorry I mwan to cut part of the object and rebind the object together. For example the object in the middle tube how to cut it and bind the remaining together again. Thanks
Message 8 of 9
memo2022
Sorry I mean to cut part of the object and rebind the object together. For example the object in the middle tube how to cut it and bind the remaining together again. Thanks
Message 9 of 9
jeff_strater
Again, this is what parametric design is made for.  I'm sure that you could modify your design to be whatever length you want, so I don't really understand why you would not want to do that.  However, if you do want to do this in a "Direct Modeling" way, here is one way:
Jeff Strater
