How to rotate view with one axis only?
jukkaNZG3H
jukkaNZG3H
In the design & animation view I need to be able to rotate the view (not move parts) with one axis only.
Is there a shortcut or another way to make it happen.
I do have 3dConnexion space mouse compact, but even with that the model is always moving to some other axis also.
If using rotation / move tool in animation space then the middle axis of a design is just whatever and it will move from side to side fluctuating. and unable to make smooth rotating animation with complex assemblies.
Phil.E
Good question. A couple suggestions:
Use constrained orbit:
And in your spacemouse control panel, there should be a way to set a dominant axis.
Is this for the animation workspace only?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
