How to resolve failed boolean operation. Bodies do intersect with eachother
Hi
I have this part (see attachment) that should be made as sum of two bodies (Kanal L and Body57).
"Combine" gives me an error:
Error:   There was a problem combining geometry together.
    If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
Failed to Boolean bodies together
The Bodies do overlap, Body57 is made as extrusion of a sketch with a projection of Body Kanal L.
Kanal L is made as loft of three sketches in different part.
How to resolve the error? (How to combine the two bodies?)
I`ve spent 2 days on this part working around different errors and I am giving up 😞
TrippyLighting
I can combine these parts without a problem.
HughesTooling
Depends on selection order. If you select this body first it fails.
That said I'm suprised it works at all, areas highlighted below tend to cause problems.
Mark
Mark Hughes
Owner, Hughes Tooling
Thank You.
