How to remove wireframe/x-ray and make it solid when placing a new component
yateslowell
Message 1 of 8
yateslowell
I am creating a wooden box to store canned goods for an emergency.
I can see all solid components when I select the top level assembly.   Fig 1.
I then create a new component (Left Side Plywood) and add a new body to it.  When I select and make "Left Side Plywood" active, I see the component I  just created and a wireframe or x-ray type view of the  rest of the assembly.  Figure 2.
The issue is that when I want to do a point to point move of the new "Left Side Plywood to move it to a certain point on the main assembly.  The multiple layers "wireframe/x-ray" image makes it difficult to find the proper destination  point.  Figure 3.
It is especially challenging when there is many components displayed and I am trying to locate the correct point to move it.  Fig 3 again.
I checked the "Display Settings -->  Visual Style --> Shaded with visible edges only" and it didn't work.
Lost and confused
                                  Fig. 1
                           Fig 2
          Figure 3
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Which software are you using exactly? I suspect you are really lost 😉
Message 3 of 8
yateslowell
Here is it is.  Thanks for looking at this.
2.0.9854
Active Plan: Fusion 360, Personal
Windows 10 (19042)
Message 4 of 8
acadhelp1
@yateslowell
I think you need to post your question in the Fusion Forum.
https://forums.autodesk.com/t5/fusion-360-design-validate/bd-p/124
Jon
Jon Page
AutoCAD Design Manager
Message 5 of 8
yateslowell
Thanks!
Message 6 of 8
TheCADWhisperer
Do you have this checked?
Message 7 of 8
yateslowell
I unchecked it and it is working fine now.  Thank you for the solution!
Not Lost and Confused Anymore
Message 8 of 8
TheCADWhisperer
Is it checked in my image?
