How to remove mates and constraints from an Inventor model on Fusion 360
deniz.kisa
Observer Observer
deniz.kisa
Observer
Observer
I have imported a step model from Inventor made by someone else and I can't remove constraints which causes problems such as;
when i make a change on a body the other twin also changes. I only want to edit single body not the other constrainted parts. I'd be happy if you could help me.
g-andresen
Please share the file and let us know what you want to achieve.
File > export > save as f3d on local drive  > attach it to the post
günther
HughesTooling
I guess the import is creating component instances. After importing the STP file, while still in direct edit mode, right click on the component in the browser and select Make Independant. note, you only get this option in direct edit mode, it's not available if you have history enabled.
Mark Hughes
Owner, Hughes Tooling
deniz.kisa
Observer
Observer
thanks a lot
