How to remove drawing windows
ArlinHorstSigns
Message 1 of 8
ArlinHorstSigns
 Hello
     Some how i have opened 4 viewing/drawing windows in fusion 360 and i can't figure out how to get back to just one window(not Split into 4 sections). Any advice would be great. when i go into viewports on any of the cubes down at the bottom it just gives the mutiple view option.   thanks in advance for you help
Replies (7)
Message 2 of 8
Phil.E
I'm surprised you cannot see the option for "Single View" on the views menu. Did you click the little black arrow next to the icon?
In any case, you can use File > View > Reset to default layout to restore the screen to one view.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
ArlinHorstSigns
Thanks I have tried the reset to default layout and that doesn't work either. No matter where I click on the viewports
It doesn't give the single view option I have deleted and reinstalled fusion 360 and it didn't fix the problem. I have it installed on my computer
At home and at work. At home it is working great.
Message 4 of 8
Phil.E
This is the first I've ever heard that this is a permanent problem.
Can you make a video showing me the steps you take? This is a good platform because it records your keystrokes.
https://knowledge.autodesk.com/community/screencast
I need to see what you are doing when trying to get out of this situation to fully understand what you are facing.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
HughesTooling
@ArlinHorstSigns  Have you tried pressing Shift+1
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
ArlinHorstSigns
Yes I have tried (Shift + 1) and it doesn’t do anything. 😊
Message 7 of 8
ArlinHorstSigns
Phil here is the screen video you requested. Hopefully this is helpful.
https://autode.sk/2KPAA7u
Message 8 of 8
ArlinHorstSigns
It's Fixed! This time to unistall I used the Clean Fusion 360.exe  and then reinstalled fusion and now it works great i have single view options and Shift + 1 works to switch back and forth. Thanks for all your help.
