How to model a thread created using the hole feature
cqualley
cqualley
I'm trying to create a modeled thread for export as STL for a 1/2" PCV conduit (1/2" NPT). I'm familiar with modeling the threads using the threads tool, but NPT is missing and seems to only be available in the hole feature. I can model a NPT for PCV pipe and fitting correctly using that tool, but it does not appear to model that thread, it's just an image/representation. Solutions to this?Screenshot 2024-10-17 at 4.31.20 PM.png
MRWakefield
Unfortunately there's no "modelled" option for tapered threads in Fusion. A solution that some have used is to insert a part from McMaster-Carr with a male thread and use that with a combine-cut. It's not ideal and it obviously depends on the McMaster-Carr part being modelled correctly but short of constructing a tapered spiral and sweeping a thread profile along it etc. it's probably your best option.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
cqualley
Okay, that's what I've come to find unfortunately, although those answers were a couple years old. Seems as if nothing has changed, thanks!
MRWakefield
Indeed! If it's any consolation SolidWorks doesn't support modelled tapered threads either. I'm not familiar with other 3D parametric CAD applications so can't comment on those.
Marcus Wakefield
