Very basic problem. Am designing a coffee table and am trying to attach the first leg (with mirror, the subsequent legs will be easy) to the top, at an angle (20 degrees from perpendicular). I'm using a rigid joint to do this, but cannot get the joint to include the angle. If I rotate the leg to the desired angle prior to creating the joint, the leg instead is joined either perpendicular, or parallel to the top (i.e. parallel to one of the origin axes). How can I get the joint to work at a different angle?
