How to export with "shaded" style?
williamw003
williamw003
Is there any way to export .3mf files with the "shaded" visual style so it hides edges? Like here after an extrusion that started from that vertical line - it seems to have exported with the "shaded with visible edges" style even though i was on shaded, so in the 3d printer software the line appears. In searches, mainly seen answers saying to delete the face,  however, there is only one in this whole side. Or that stuff isn't touching together to join properly, but i extruded from the face itself so i don't think that'd happen. Strange thing is i did the same on the right side of the rectangular hole, and it didn't create that visual artifact
Fusion:
3D modelling software:
It was originally a 3d print file, which i then generated faces + converted mesh
TheCADWhisperer
@williamw003
Attach the original file too.
With a section view observe that there is an extraneous face buried within the model.
Check scale of the model before all else (I failed to do that first step in the Attached).
williamw003
Here
TheCADWhisperer
@williamw003
Check back in a few minutes for a video on how to repair the model.
What a Fusion Mesh to Fix
