how to elimenate these images and make board cuts
cvbsDTXM7
cvbsDTXM7
Hello All
 First question ... as you can see on the .pic I have what appears to be offset faces on the bottom of my work piece.  I have tried to select and hit delete with no success.  How can I remove them?
Second... I am trying to cut the "end" boards so the fit within the octagon ring.  Each time I select "line" to cut the angle it takes me back to the sketch area.  Is there a way to make the line and then do extrude right on the piece with out going back to the sketch?
Hope this all makes sense and if questions let me know.
tia,
cvbsThis is lookin it from the bottom. The "yellow" areas I can not delete !!This is lookin it from the bottom. The "yellow" areas I can not delete !!
g-andresen
1. what you mean are origins of several components.
    You can turn them off by making the origins in the components invisible.
2. please share the file with us and we will look at how to cut them out.
günther
cvbsDTXM7
I don't know if my computer is having a problem with keeping up, however when I came back to the system to reload fusinon360 the "planes" did not appear.   Suggestions?
I would like to up load the file however I can not locate it on my system. Is it only saved in the cloud and if so how can I get it to you to evaluate.   Each time I have tried to cut one of the boards it cuts all on the left side.  I did use pattern to make from center board.  My objective is to cut each angle to fit within the octagon.
tia
cvbs
cvbsDTXM7
I think I figured out how to access the file.
Let's see if this works 🙂
g-andresen
I see that all component origins are now invisible.
günther
cvbsDTXM7
I turned them off, is that a problem?
g-andresen
Not at all!
günther
