How to Drill at 45 degrees? And cutting holes at 90 degrees? I have a box with holes on the sides I need to mill out and I need to drill at 45 degrees.
pdjXU638
Message 1 of 18
pdjXU638
Replies (17)
Message 2 of 18
davebYYPCU
Plane on Angle, at 45 deg
Sketch centre points.
Use Hole Tool from sketch Plane.
Might help....
Message 3 of 18
pdjXU638
I am new to Fusion so some of the instructions are not clear. Is there a
video that shows this?
Also, how can I cut out a hole or profile on the side of a box?
Message 4 of 18
davebYYPCU
What I said.
Might help....
Message 5 of 18
pdjXU638
Thank you for your help.
If anyone else could add more that would be great!
Thanks again
Message 6 of 18
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
Message 7 of 18
pdjXU638
This comes from tinkercad.
I would like to drill B at 45 C at 45 around the block as a demo.
I do not have holes drawn in the sides yet.
But I will need to carve shapes in the sides as well. But I do see how
to do this.
Message 8 of 18
davebYYPCU
File from Tinkercad is STL format.
My suggestion does not work for your (missing) file format.
Might help....
Message 9 of 18
g-andresen
Please provide at least pictures for a better understanding.
Günther
Message 10 of 18
pdjXU638
Here is the file converted to fusion.
What I need is a visual on how to drill the 4 corners at B 45 C45. I
just want to located the 4 corners, so it does not need to drill deep.
I am looking for a way to verify the setup. Not sure if fusion can do
this, I cannot find a video that shows this.
If you know of one please let me know.
Message 11 of 18
davebYYPCU
No file.
Message 12 of 18
pdjXU638
Here it is
Message 13 of 18
jhackney1972
No file again.  You cannot attach files from an email link, you have to come to the Forum and Attach them to a post.
John Hackney, Retired
Message 14 of 18
pdjXU638
Oh
Message 15 of 18
g-andresen
Is that what you want to achieve?
günther
Message 16 of 18
pdjXU638
yes, that's it!
No speech, I am new to fusion so explaining what you are doing in the
video would help me a lot!
Thanks!
Message 17 of 18
g-andresen
@pdjXU638 wrote:
yes, that's it!
Follow screencast and timeline.
1. create a diagonal
2. insert a plane on the path at the start/end point of this diagonal
3. this plane takes up the sketch for the hole and the countersink and ...
4. ... forms the basis for an offset plane, which is required for drilling a hole along the diagonal and also for the subsequent countersink
5. drilling and countersinking are transferred to the 4 corners in a circular pattern
Message 18 of 18
pdjXU638
3 Thumbs Up!!!
This gives me a great head start!
Thank you very much
