how to draw R100 LOFT parth
wsirrigation026kan
Message 1 of 10
wsirrigation026kan
Community Visitor
Community Visitor
I would like to know how to draw R100 loft parth in attach drawingphpi0PDdt.png
Replies (9)
Message 2 of 10
jeff_strater
I did not do the whole thing, just showing how to get started with the main part of this object.
  1. create the two blocks, using sketch + Extrude.  Look at the timeline for details, but you will need an offset workplane as part of it (to get the 140 distance)
  2. Then create a centerline sketch with the two arcs:
  3. next,  create the loft.  Be sure to specify tangent end conditions, and choose "centerline" for the rail
  4. then, create the variable radius fillet.  I just did one edge.  The key is to set two midpoint conditions, at the edge endpoints, and set the radii appropriately
sample is attached.
Jeff Strater
Engineering Director
Message 3 of 10
TheCADWhisperer
@wsirrigation026kan
Is this a school assignment?
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
In any case, make sure that your sketches are fully defined (blue lines/arcs should keep you awake at night).
Also, the 32mm on the Hex (actually not a Hex because of this dim) does not make logical sense to me.
Can you ask the source to join this discussion?
Message 4 of 10
davebYYPCU
Me too.  (Edit - think I have it now)
@jeff_strater Couple of things,
Where did you get the 70 dimension from?
you have not used the 10 dimension in the path.
Not used the 2 x 22.5 dimensions,
bottom of both blocks are 45 apart, you have 52.5
Tangent connection would upset the 140 lines in top view.
Might help...
Message 5 of 10
TheCADWhisperer
@davebYYPCU
Where did you get 2 x 22.5 from?
OK, I found it.  Actually I see it in the 3D annotation but do not understand the logic of why it was dimensioned.
This drawing is terrible.  I suspect that it does not match true Design Intent.
Message 6 of 10
davebYYPCU
Amen.
Message 7 of 10
jeff_strater
"Where did you get the 70 dimension from?"
I guessed, because it was under-specified.
Jeff Strater
Message 8 of 10
davebYYPCU
Using that centre line rail does not provide the drawn result.
Might help.....
Message 9 of 10
TheCADWhisperer
If the OP returns - I will give it more time.
Here is my supposition:
Based on 30 years of teaching 3D design this looks to me like a class assignment that was not well thought out.  Over the years, students would find issues with my assignments to them and I would refine as appropriate. In some cases I made the same mistakes for ten years before a student would say, “Shouldn’t that be…” and I would immediately incorporate their improvements.
And being in the business of education I would see a lot of work by other instructors who apparently didn’t learn from their students.
I made some changes on Tangency and on the "Hex".
Message 10 of 10
davebYYPCU
Sure, understand that, (agree that the original data is crap)
we are both suffering distorted bottom surface silhouette (highlighted) , not matching the 2d graphic.  Your connection to the bottom plate looks Yuk, but the tangency there would help, presume you haven’t modified yet.
Can be fixed, external rails.
