How to draw line between these 2 points?
michaelob
Observer Observer
michaelob
Observer
Observer
Please see attached image. How do I sketch a line between the 2 points I highlighted with the red arrows?
I'm new to CAD/fusion, and if I click into sketch mode, then try to click on those points, the actual line gets drawn not where those points are- almost like it's going deeper into 3d space than I want.
Any advice on how to do this would be appreciated thank you
davebYYPCU
Depends on what you are going to do with the result.
Start a Sketch on the lower flat side of the case where the bottom arrow is.
Create > Project > Project the points where the arrows are pointing, into the sketch.
Draw the line connecting the 2 purple points.  Finish Sketch.
Use Modify > Split Face, select the curved face - select your sketch line.  Fusion will split that curved face in half, show a black edge line, for further work.
Might help...
TheCADWhisperer
@michaelob
For future reference - it is always best to attach your actual geometry file rather than a mere image if possible.
