How to display dimension units in Drawing
undividedwholness
undividedwholness
I want the dimensions shown in my drawing to include the units. I found a knowledgebase article but it's out of date. The Preferences -> General -> Drawing dialog no longer has a Display Units checkbox and I don't know what to do.
HughesTooling
Expand document settings then select dimension units and then on the settings dialog check the Unit Abbreviation option.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Note, the option above will work for existing drawings. If you want all your new drawings to show units you can override the setting in preferences. Another option would be to make a template.
Mark Hughes
dsouzasujay
Hi @undividedwholness ,
It should be here
Edit:
Fastest first @HughesTooling
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
undividedwholness
Awesome, that worked. Thanks very much.
vertunc1976
Why after so many years and with the realith that we are paying fees to use this Fusion 360, the drawing module is absurdly weak?? I can not make a simple drawing with dimensions on it? Why The sketch mode in drawing module is as simple as a preliminary shcool drawing interface??
vertunc1976
No as usual, autodesk cercificate managers can not post a comprehensive solution to anything!! Just a tick and it is solved?? Nooo, please make real advancements to drawing module with real tools for sketching and dimensioning. I invest so many days to learn this software. please
