How to delete a sketch pattern ?
Dear forum members,
Imagine one has made a sketch pattern of many elements, does not need it anymore and doesn't want to spend time selecting and deleting all the individual elements. Is there a fast way to delete the whole pattern ?
davebYYPCU
Window Select,
or Delete sketch,
not working for you?
Window Select selects too much.
Delete sketch deletes too much.
jhackney1972
The fastest way has already been suggested, delete the sketch.  If you want to remove just the sketch pattern, it will take you a couple of steps.  Take a look at the Screencast.  If you switch to using a model pattern, and you use the timeline, you can remove the pattern in one click from the timeline.  Fusion 360 performs better with model patterns than sketch patterns also.
John Hackney, Retired
Reducing the number of instances in the patern looks like a procedure that should work and that I should have thought of myself. Alas, it does not. No pattern constraint symbol is visible. I remember I could make one appear before, but not anymore. Also, I am able to modify the pattern instances independently. I suspect the pattern constraint has been deleted.
