how to create a section view that is exactly perpendicular to an edge of the workpiece?
alexanderhermann83
alexanderhermann83
jhackney1972
It is a multi-step process but easy to do.  I created a Screencast on a model I created similar to your.  At the end of the video I mention you can remove the alignment of the section view if desired by pressing, not holding, the shift key as you drag.  I used an ASME template but the process is the same for an ISO template.
John Hackney, Retired
alexanderhermann83
Dear John, thanks a lot for this solution! That helps me.
But it is a quiet complicated way, I hope Fusion 360 team will make a better solution for that.
alexanderhermann83
Dear John,
maybe I found a better solution for creating perpendicular section views.
The clue is to make a sketch in the design environment where you can use a more powerful skatch featurest.
Please watch this screencast and tell me what do you think about this solution:
alexanderhermann83
jhackney1972
Yes, I have used this technique also especially for creating special dimensions that do not have snap points in the drawing environment.  Here is a link to my blog article and video talking about these.  I hesitated suggesting this method before because many users do not want to return to the modeling environment to define geometry that can be used in the drawing environment.  I can see you are open minded about this method.  I am impressed you worked at it to find another option.
