How to close the loop from an offset lines or splines?
hclmed
hclmed
Is there a way to close a sketch that has a pair of splines created by an offset? When try to simply connect their endpoints with a line segment it doesn't snap to or detect the endpoints, so the lines can't be joined into a closed loop. The same would apply to just close 2 or more disjoint lines into a 2D polygon. What's the procedure for joining disjoints shapes on the same plane into a surface?
TrippyLighting
Can you post your model? Export as .f3d and attach to a post.
hclmed
Ok, mystery solved. I see that once a sketch is re-opened, it can be appended to and closed. I just need to get used to recognizing when a sketch is open or not by watching for the FINISH button on the far right of the menu. Thanks.
