How to add details to a a tapered surface
LunarHamster
LunarHamster
Hello! I would greatly appreciate advice on how to create the ridges shown on the model below. They are on the inside and the outside of this tapered cup.
Sorry if this is a repeat. I posted it earlier but my post seems to have disappeared.
Screenshot 2025-04-22 at 17-34-38 Pint Pal (Ice Cream Pint Holder) by TomNeffs24 Download free STL model Printables.com.png
HughesTooling
First create the main body using a tapered extrude. Then create sketches on the faces for one of the ribs and loft.
After the loft pattern the rib around the body. In your image the ribs don't seem to be tapered so the gap between is bigger at the top.
Then repeat for the inside. See attached file.
Then use a revolve to add the chamfer.
Mark Hughes
Owner, Hughes Tooling
TheCADWhisperer
@LunarHamster
Revolve and Pattern.
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply if you can't figure it out?
LunarHamster
Thank you, Mark! I learned so much just now! Showing the chamfer with revolve step was a surprise bonus!
