How do you scale an image that you insert into a drawing
myyxlplyyk
myyxlplyyk
I have a drawing where I can have the model be 1:1 and it fits on the page. I can insert an image, but after I click OK, I can't move it or scale it. It's just locked with the drawing. Do I need to insert an image scaled to the exact size?
-KyleWilliams-
Hey @myyxlplyyk
You should be able to move and edit the scale of the image.
To select the image you will need to click the "edge" not the center to select it. Double clicking will bring up the image edit dialogue you would have seen on insert.
You can also manually drag to move, or select the corner points and drag to scale.
Let me know if you are seeing some other behaviour.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
myyxlplyyk
Oh man... ok. Yes that did it. Another case of a user going "I thought I did that" plus "obviously not". 😆
