How do I mount a coil spring on to a shaft.
b.robertsonYBD22
b.robertsonYBD22
I have drawn a coil spring and a shaft and don't know how to slide the spring over the shaft. I have tried the Assemble, Joint command without success. I would appreciate some assistance if possible.
TheCADWhisperer
TheCADWhisperer
Sketch line or circle.
jhackney1972
You did not attach your model so I am only guessing on your shaft and spring configuration.  I created a simple spring and shaft and placed a Slider Joint between them.  The shaft is grounded.  Please attach your model so the Forum users can match your exact needs.  Model is attached.
John Hackney, Retired
b.robertsonYBD22
Thank you for your reply which really helped me a lot. This was my first post so I will need to take more time to work out how the forum works!
