How do I join my bodies and removing the faces between them?
agnny682
Message 1 of 10
agnny682
This may be a beginner's question but I've just made a shell out of my bodies, which kind of worked except that the faces between the bodies are still there. I know that they would not be removed by shelling the bodies, but I still wonder how to remove them since this project is about casting plastic - so the faces has to go.
Thanks in advance!
Replies (9)
Message 2 of 10
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 10
TheCADWhisperer
@agnny682 wrote:
… made a shell out of my bodies,
Did you intend to Combine into one Body before Shell?
Message 4 of 10
agnny682
I've tried to combine all the bodies together before Shell, but also with all the bodies separated - but nothing seem to work 😞
Message 5 of 10
agnny682
Great! I've shared a copy of my work below 🙂
Message 6 of 10
jeff_strater
is this what you are after?
Jeff Strater
Engineering Director
Message 7 of 10
agnny682
That's right! Thanks! That's exactly how I want it to look, but I also want to add holes to the two piles like the front one. Could that be possible? When I have combined all of my bodies the shell function doesn't work and a warning pops up.
Message 8 of 10
g-andresen
The reason for this is in Sketch 1, where there are sketch elements that lead to unclean boundaries to the adjacent solids.
günther
Message 9 of 10
agnny682
Wow! Amazing! Thank you so much and especially for the helpful video! 😄
Message 10 of 10
g-andresen
I recommend that the shell is  created after the outer fillets have been attached.
günther
