How do I extrude a drawing 5mm, using the shape of the inside of a body?
I need to create a supporting plate for the base of a field element in the current VEX V5RC game. Picture of the piece below, I have a STEP file for it. The "cone" was manufactured with the walls too thin, and as a result, in use (robots banging against it), the mounting holes crack and fail. My idea is to create a 5mm thick "plate" that goes inside the base so that when an impact does occur, the stress of the impact is shared across the base.
Here's what I have tried (with a basic understanding of Fusion 360):
* Import the shape (STEP file) of the base
* Sketch a circle the diameter of the base "under" the base on that plane
* Extrude -> 5mm (towards the interior of the base) -> Extent type "To Object" -> (Select cone as object) -> Operation "Cut" (but no objects show up in the objects to cut)
I get a "Cannot complete extrusion" error with message "Error: Cannot complete extrusion.
Cannot extend extrusion to object. The extrusion profile falls outside the boundary of the selected body. Select a face or plane instead, or adjust the profile so that it falls inside the boundary of the selected body."
And I'm stuck. I literally just want to do a boolean join on the base, leaving the geometry for the inside of the base so that the two pieces would fit together, but I cannot for the life of me find a simple boolean tool for multiple shapes (when one exists in MS 3D Builder that works more or less fine). I'll use 3D builder if I have to, but I have additional operations to perform on the base support for a better 3D printed end product so would rather just get Fusion 360 to work.
Help? Please?
The base:
