How do i create a ramp
iuliancalin22
iuliancalin22
i'm fairly new to fusion 360 and i need some help.
i want to crate a ramp on a sketch but i'm kinda stuck cause i don't know were to start.
as you can see below i have the extrusion marked with blue, i would like to make it so i have like a ramp on the line marked with (3) , were the ramp starts from (1) and goes to (2). the extrusion is 10 mm at (1) deep and should end in 5mm deep at (2).
is it possible to edit somehow the already made sketch?
jeff_strater
Split Face and Draft should get you there.  Can you share the model here?
Jeff Strater
Engineering Director
jeff_strater
something like this:
Jeff Strater
iuliancalin22
thank you so much for that video. so far i only worked on the creation part and didn't touch the modify side, and cause of that i found more tools to work with. turns out there is more to those tools and i ended up with this smooth exist in the picture below
btw i atached my project if you are interested, maybe some feedback
