How can I cut this spline?
To loft the head part, want to cut this highlighted spline using "break" in the sketch mode. But the ribs are made after and is referenced by the spline, so when I enter "edit sketch", it appears like this, with no ribs.
How possibly can I cut this spline??
g-andresen
Please share the file.
1. What sketch
2. position for cutting
File > export > save as f3d on local drive  > attach it to the next post
günther
I want to cut the top spline and the bottom spline of the sketch with all intersecting lines.
g-andresen
1. create a new sketch on the same plane as Sketch 9
2, project the contour (sketch 9) into it (projection link unchecked)
3. create intersections to involved sketches
4. "Break" spline at desired points
günther
