How can I change my design by drawing a plane down it and extruding along that plane without changing other dimensions?
Shan-d-man
Message 1 of 8
Shan-d-man
I have a design that I now need to make a modification and cut out 5mm from the exact middle without changing any other aspects of the design.  I can't just resize the design or nothing will fit.  I can't seem to figure out how to slice this vertically and make it shorter horizontally.
Replies (7)
Message 2 of 8
HughesTooling
If you fully constrain the sketch correctly you can just change the overall width and that's it.
Looking at the sketch it looks like you should have just created one half, extruded then mirrored to create the other. Edit looking closer you should sketched a quarter and mirror the extrusion twice. Symmetry constraints should be kept to a minimum in sketches as they seem to use a lot of resources and slow fusion down.
Golden rule with sketching is keep the sketch as simple as possible and mirror and pattern features not sketch entities.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
TheCADWhisperer
This will be easy to solve.
@Shan-d-man
Message 4 of 8
Shan-d-man
Yeah, I have a lot to learn on how to organize the sketch while I am building it.  This was literally my first sketch.  Here is the .f3d file
Message 5 of 8
TheCADWhisperer
@Shan-d-man
Tip 1. Blue lines and white dots should keep you awake at night.
I recommend that beginners create only one line or rectangle at a time and fully define it immediately before proceeding to next line/rectangle...
Back in a minute...
@Shan-d-man
At any time you find yourself duplicating dimensions you are working too hard.  Stop and ask questions...
Notice how few dimensions I have...
Notice that all lines are black (fully defined size and position).
Message 6 of 8
TheCADWhisperer
@Shan-d-man
Examine the Attached file.
Double click on any dimension(s) in Sketch1 and edit as desired (within reason).
The model should automatically update.
If for some reason the results do not update correctly and you cannot figure out how to fix the issue - post back with additional questions.
(BTW - there is also a way to do what you originally requested - but that isn't really the most efficient technique so I didn't give you that answer.)
Note: When you edit dimensions notice that many of them I divided by 2 (desired total divided by 2) since I only modeled 1 side of quadrant as suggested by @HughesTooling .
Message 7 of 8
Shan-d-man
Thank you (all), that was quite helpful.  I have been going along happy with me being able to get it into the right shape.  I never knew I had to pay attention to those little dots.  I can edit the sketch you cleaned up, but I can't seem to do this with mine.  It gives me an error when I try to resize.  I think I have some learning to do.  Did you redraw this or were you able to clean up my original sketch?  Any topics I should pay attention to in the learning videos?
Message 8 of 8
TheCADWhisperer
@Shan-d-man
I started over from scratch.
I almost never use someone else’s work I’m my own work.
