Hole wizard improvments! or am I missing something?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Guys and Girls,
I have been using fusion for some time now and are frustrated that the hole wizard seems to be incomplete.
1. You can create a number of hole types,
I generally have to create a basic hole and with thru holes I set the constraint to though all then I have to add a chamfer via the modify menu to the bottom face of the hole. why is there no function to do this with in the hole wizard?
2. Counter bored holes,
You can create a counter bore d hole thats great but you have to add chamfers thought the modify function again why cant this be done within the hole wizard?
3. Taped holes,
You can create taped holes no problem with a chamfer to the top of the hole but you have to add a chamfer to the bottom edge of a through taped hole, why cant this be done with in the hole wizard?
4. Counter sunk holes for counter sunk socket head cap screws.
When you create a counter sunk hole you set the size to suit the screw size being used but in some instances you want to set the depth of the hole deeper without making the major diameter of the counter sunk portion of the hole bigger than needed, the only way that I have been able to do this is to use the counter bore function and then modify to suit then manually add chamfers after hole is created.
5. Advanced hole generation.
When creating parts that bolt together you can or have to create your hole to go through the part to be bolted (clearance hole of required type) in to the part to which the part is being bolted to, then you have to add a thread to the hole in the part that is needing to be taped again why cant this be done in the hole wizard?
6. Holes on the end face of a round part to create a PCD.
This seems to be only possible through the scetch and extrude method for when you try to do this with the hole wizard and you go to add a reference to the center point of the part the hole wizard snaps the hole to that point and does not allow yoou to set a dimension from the center point of the part.
Note these are common functions that are used in the design process not just by myself but in industry on the whole and should be standard functions of the hole wizard.
