Hole Tool Bug with To option.
HughesTooling
Consultant Consultant
HughesTooling
The hole tool works once with the To option but on a second use it doesn't work correctly.
In the screencast I've use the hole tool with the to condition, to get it to work again you have to mess around dragging then selecting To, I can't just select a face.
Thank mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
Good catch Mark, I see the same thing - you should just be able to select a face and get it to work, but you have to toggle between distance and "To" to get it to work.  We'll take a look
Thanks for reporting it.
Jeff
[edit]  filed as FUS-33521
Jeff Strater
Engineering Director
