Hole presets
Hole presets
eric_engineer
Message 1 of 1
Hole presets
eric_engineer
Is there a way to have a bunch of preset holes I can call up when I want to use them?  I'm tired of manually going back to other designs, looking for the hole that worked well for a threaded insert, then manually typing it in again.
I'd like to have a list of named holes I've created so I can quickly call them up again in the same design and between different designs.  Beyond just being slow it's an area that's easy to make a mistake.
Also a way to just keep using the hole tool after I place one without having to go back and click the hole tool again. If I have to drill 10 holes that's a pita.
Thank you.
Replies (0)
