- Mute
- Permalink
- Report
I am using the non-commercial (free) version of Fusion.
I imported a mesh, then did a Modify -- Convert Mesh. This created to Solid Bodies, which I then combined into a single body. This body is essentially a hollow box, but each face is made up of several triangular segments, which I've been unable to combine (maybe a question for another time, unless it's relevant). The inside face of the base of the box has more triangles than the outside face.
I then selected the triangles making up the base of the box and extruded it 4mm to thicken the base. I want to create screw holes on the bottom of the box. I first tried a "Hole" and then also tried putting a circle on a sketch and doing an Extrude -- Cut. In both cases, I got an error message saying that Fusion could not find a body to cut, unless I set the distance to more than the total thickness of the base (5.191mm). If I set the distance to 5.191mm or less, I got the error and could not complete the cut. If I set the distance to 5.192mm or greater, the operation completes successfully.
Thanks in Advance for your help.
Ron Ventura
