Hole feature in sheet metal part issue
tonySWCR2
Message 1 of 11
tonySWCR2
The hole feature is not remaining where I place it on a sheet metal component, any ideas?
Replies (10)
Message 2 of 11
TheCADWhisperer
Why do you have a Move in your Timeline before the Hole features?
What if you expand the Objects to Cut target body selection?
What if you click on the More Info?
Why is the browser not shown?
Why use Extrude and Convert to Sheet Metal rather than model as sheet metal?
I have tried everything I can without actual file, and this is the only way that I can come close to reproducing issue.
Message 3 of 11
tonySWCR2
No as it is part of an assembly that contains IP of the company. However, I can save as a new file and see if the behaviour still exists then upload that.
The component is currently in free space (in the assembly) so I am using the origin to maintain its location, hence the move. I could have created a plane at the offset I wanted and made the sketch there but the move body feature exists so I used it. I just suppressed it and the problem persists.
see new screencast
Precaution. To not show any company IP
The part was originally to be 3D printed, then it was required it was changed to metal so I just converted the part.
Cheers,
Tony
Message 4 of 11
tonySWCR2
File added
Message 5 of 11
TheCADWhisperer
What happens if you Flip the direction?
BTW, I would probably use Joints to locate components.
Message 6 of 11
tonySWCR2
Just tried that and this is for sure a bug. If i flip it then it does intersect the part but its not right.
Things to note:
The hole is now going the wrong direction
The starting plane is not the one I specified OR any plane that exists in the model
It consistently changes my 7.5mm offset to 5.303mm and then moves the hole again when I exit the hole tool
I have joints constraining the origin to the main assembly origin, hence the move to put the part where I want it to hover in space.
Message 7 of 11
TheCADWhisperer
I would modeled the part differently (starting from the sketch) and would not have encountered this issue - but this is interesting find.
Ping @jeff_strater
Message 8 of 11
tonySWCR2
I just modelled it from sheet metal completely and the problem does not exist. There is an issue none the less, how does this get flagged to Fusion 360 developers?
Message 9 of 11
TheCADWhisperer
@tonySWCR2 wrote:
...how does this get flagged to Fusion 360 developers?
I already pinged @jeff_strater , he must be out for doughnuts, let's try @Phil.E .
Message 10 of 11
Phil.E
The problem seems isolated to either this part, or the hole command logic. I sent this to the sheet metal developers to have a look. It would help to know how common this is, so if you find the same result, using the same workflow (or one like it), please post again.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 11
pedrobraz8PBU2
Community Visitor
Community Visitor
lifesaver!
