history applying order problem, late actions applied to early operations.
hi, i made this texture sample, i wanted to raise the pipes a bit from the circle base, so i extrude in a negative number the upperface of the circle, however, the effect is being applied after the combine leaving a weird hole between the mesh and the circle top face. can somebody help me to fix that? i would appreciate if somebody do the modification and explain it to me.
https://a360.co/3asU23P
the solution is remake everything
