Hiding bend lines in flat pattern
WillGKDMN
Message 1 of 8
WillGKDMN
Hello all,
I was working on a gasket between two folded sheet metal parts, so to match the parts I modelled the gasket as a sheet metal part in between the two components, it fits well and the advantage I figured was that I could use a flat pattern to get the gasket sent out and cut. The problem is no matter what I have tried I cannot hide the bend line, it appears as a centre line style line and makes the drawing confusing. Any ideas?  I can't send any images because of an NDA.
If there is no solution and fusion developers want a quick solve, there are settings that can change the line colour on fusion drawings, if the fusion developers offered a transparent option with the colour choices - I think there is a unique hex code for transparency - then that would be a quick and simple solve.
Kind regards,
Will
Replies (7)
Message 2 of 8
davebYYPCU
I presume you are saving the flat pattern as dxf file, edit that file and remove unwanted articles.
Might help....
Message 3 of 8
WillGKDMN
A DXF is also exported but a properly dimmed drawing is needed, and is created on a standardised template.
Message 4 of 8
jhackney1972
You can remove the Bend Lines by going into the 2D Drawing Document Setting, from the Browser, and then change the color of the Bend Lines to white so they will not be visible or print.
John Hackney, Retired
Message 5 of 8
WillGKDMN
Yeah, I already found this, it does work but it still causes a small line break, fine if you only have 1 bend but if you have several it looks like a drawing error. I know I am being a pedant, but I just thought I'd check. Thanks for trying though, much appreciated.
Message 6 of 8
james_r_hutchinson
From memory, find flat sheet in the model tree on the left hand side, in the nested drop down there should be options to turn off bend lines or bend extents.
Message 7 of 8
jhackney1972
You are correct but the setting in the model do not carry over to the 2D drawing.  There is a selection check, in the view placement dialog, to turn off Bend Extents but not Bend Lines.
Message 8 of 8
ClintBrown3D
Hi @WillGKDMN
Once you have exported the DXF, you can always turn off the Layers that are exported. In the example below, I am using AutoCAD.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
