Hidden objects: can I make them unselectable?
knifacat
knifacat
The main reason I hide objects (bodies, components, sketches, etc) is that they are cluttering the workspace or aren't relevant for whatever action I'm currently trying to do. However, faces and profiles of components still seem to remain selectable, even though they are invisible. So you can't see the component or whatever, but if you mouse over the blank scene it still pops up.
Is there any way to disable this?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @knifacat,
Can you create a Screencast documenting this? I saw someone else posted about this the other day too, and I cannot reproduce it. A hidden body should not be able to be highlighted just by hovering over the blank space in the modeling workspace.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
knifacat
I've just boot it all up again to try get a recording and it doesn't seem to be doing it anymore! It's been fairly consistent for me so I'll try grab one next time it happens.
knifacat
It's been a while but I finally managed to capture what I mean. The lines that would be available for projection from the sketch plane are selectable even if the object they're coming from is hidden in this case.
Screencast will be displayed here after you click Post.
51c29408-9f47-48d9-ae5a-cfa6cbdc984c
Here's the screencast (forum seems to be glitching out trying to edit the post with it... ?) https://knowledge.autodesk.com/community/screencast/51c29408-9f47-48d9-ae5a-cfa6cbdc984c
westre4196
Community Visitor
Community Visitor
I'm having the same issue. Every single body remains selectable when hidden, making it impossible to click underneath it until you un-hide, then re-hide, the body. Everything has to be hidden and unhidden and rehidden every time. But if you interact with the body, like use it to combine/boolean subtract, it becomes fully selectable again, and I have to hide it again. Even when I make the body unselectable.
