Hi guys I'm very new to fusion 360 and I'm trying to design a golf aid as I'm a PGA pro
FacebookGroupMember
Message 1 of 19
FacebookGroupMember
Hi guys I'm very new to fusion 360 and I'm trying to design a golf aid as I'm a PGA pro. Does any know what thread size a standard tripod screw/camera is. I need to be able to mount the device on a tripod. Thanking you in advance.
Replies (18)
Message 2 of 19
FacebookGroupMember
I’m also fairly new at this but it seems like it might be a better idea to make slot for a captive nut you could slide in, that is if you plan on getting your device 3D printed.
Message 3 of 19
FacebookGroupMember
Pretty sure 3/8-16
Message 4 of 19
FacebookGroupMember
I was close!
Per ISO 1222:2010, the current tripod bolt thread standard for attaching the camera calls for a 1/4-20 UNC or 3/8-16 UNC thread. Most consumer cameras are fitted with 1/4-20 UNC threads.
Message 5 of 19
FacebookGroupMember
Thanks for the feedback Tony,,but what do I actually select in fusion360? What diameter and thread size settings. Cheers
Message 6 of 19
FacebookGroupMember
3/8" is the diameter 16 threads per inch. Or 1/4" diameter and 20 threads per inch
Message 7 of 19
FacebookGroupMember
Thanks Tony much appreciated
Message 8 of 19
FacebookGroupMember
Tony Boersma if you want to make a 3/8-16 tapped hole,, the drill for the tap is a 5/16.
Message 9 of 19
FacebookGroupMember
Tony Boersma can insert a McMaster carr part as well
Message 10 of 19
FacebookGroupMember
Bill Wanick diameter minus pitch is what i was taught. Rule of thumb at least.
Message 11 of 19
FacebookGroupMember
Dave Jensson i love the mcmaster feature
Message 13 of 19
FacebookGroupMember
Tony hadn't heard that... might work? 🙂 I always learn something new
Message 12 of 19
FacebookGroupMember
Would these settings work for the tripod screw?
Message 14 of 19
FacebookGroupMember
Bill Wanick it gets you pretty close 3/8-1/16 = 5/16 like you said. Metric is easier m4-.7 would be 4 minus .7 = 3.3mm.
Message 15 of 19
FacebookGroupMember
Alan Mulford you want the unc profile drop down. I don't know what metric tripod sizes are
Message 16 of 19
FacebookGroupMember
Thats what the random drill chart i saw said... close enough to make em aware that its not just a 3/8 hole for the tap.. 🙂
Message 17 of 19
FacebookGroupMember
Bill Wanick I've drilled it 3 times and it's still too big!
Message 18 of 19
FacebookGroupMember
Tony sounds like someone that's done that a time or 2...
Message 19 of 19
FacebookGroupMember
Bill Wanick is 2 a million rounded down?
