HELP!!!
HELP!!!
HELP!!!
How do I insert a print from the web (specifically from Thingiverse) on to Autodesk Fusion 360!?!
I have tried to download it and I could only do a mesh.
HELPPPPPPP MEEEEE
Teddy,
If you downloaded a STL file from Thingiverse, you can insert them into a project using the "Insert Mesh" functionality.
You can find documentation for this here: http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3C2DDE80-CC41-4516-88E6-1F3EDC6CF62A.
In my experience, modifications to STL are very limited and I typically just use this method to reference them for re-creation.
- Charles
paul.clauss
Hi @Anonymous
Thanks for posting! @Anonymous is correct - you can use the "Insert Mesh" tool to get the mesh file from Thingiverse into Fusion 360. I also wanted to provide you the link to our guide on inserting and opening data in Fusion 360. Hopefully this will help you out in the future!
Paul Clauss
Product Support Specialist
Thanks both of you!
