Help
Help
carterszydel5228
Help
carterszydel5228
I am making this contraption that when soft dog food is push through it will cut it into even cubes, I need to make a push down tool that matches the pattern of the blades, and also has a offset because this will be 3d printed.
jhackney1972
I have attached a model of a plunger that goes down to the second set of cross-cutters.  I have parameterized the slot widths so you can adjust it to anything you desire.  Right now it is 0.1mm clearance per side.  I left the top of the plunger plane so you could add any thing you desire to hook it to the rest of your machine.  There is an Assembly Joint that allows the plunger to move from the lowest position to 50mm up.  Model is attached.
John Hackney, Retired
TheCADWhisperer
