Help
Help
caddder28
Help
caddder28
Community Visitor
Community Visitor
Hey all,
I am relatively new to fusion 360, I am curent trying to make a steel sheet bender out of steel angle.
my question is can i make the piece of steel clamp between the angle and bend when the angle is pulled up to bend the steel  https://youtu.be/fJ5LZEYyjiU  . so what i am asking is can you make a model bend steel ? how can i make the top piece of angle clamp a piece of steel between the bottom piece or angle  then bend it by lifting the other piece of angle????Screenshot 2024-08-26 005230.png
davebYYPCU
You don't need that machine to bend metal in Fusion.
Use Sheetmetal > Create > Bend. needs the flat plate and a sketch line.
You can model the Machine, but it won't bend metal for you, see above.
Might help...
