Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
HELP TO MOVE MY FILES
paolo.recchi
Message 1 of 9
paolo.recchi
Dear All,
I'm a F360 user since 2013
I've got all my data stored inside Autodesk 360 experience (it seems system folder) so know for me it's not possibile to move all my files/project to other folder external on Autodesk 360 experience.
I NEED help to solve that cause it's no possible to make a team with all my data.
PLEASE PLASE HELP ME!!
Replies (8)
Message 2 of 9
jhackney1972
You are a little vague about where your Fusion 360 projects are stored now but if they are in Single-User Storage, as shown in the screen capture below, then this article is what you need to get them into a Team.
John Hackney, Retired
Message 3 of 9
paolo.recchi
Thank you so much for your reply.
I try to explain myself as better as possible.
I’ve got a single user cloud since 2013 -
I stored all my data inside project folder Autodesk 360 experience (screen shot 01 attached)
Inside this folder I stored a lot of data (some giga I think - distributed inside several folders with child folder inside and so on) (screen shot 02-03)
I know about page on the link below, but when I try to move my data form root folder to team folder there’s no way to do that, because my data are inside a folder that doesn’t show from by the possible choice (screen shot 4)
I've tryed to ask help in several channel you offer but it seems there’s no way to solve.
I’m available by phone +393403785417 - or zoom or what way you prefer, but I need to unlock the situation.
Many thanks for your time and attention to this issue.
Best.
Message 4 of 9
paolo.recchi
I try to explain as better as possible.
Inside this folder I stored a lot of data (some giga I think - distributed inside several folder with child folder inside and so on) (screen shot 02-03)
Best.
Message 5 of 9
HughesTooling
@James.Youmatz might be able to help with this.
Mark Hughes
Owner, Hughes Tooling
Message 6 of 9
paolo.recchi
I sent him a PV_
I'm crossing the finger.
Message 7 of 9
James.Youmatz
Autodesk Support
Autodesk Support
Hi @paolo.recchi ,
You cannot transfer folders from single-user storage to Team Hub, only entire projects. In your scenario you would have to transfer the entire Autodesk Fusion 360 Experience project (shown in your screenshot). Are you able to transfer this entire project, or is there a reason you cannot?
If not, I do have an idea, which would be to Move or Copy the data from that folder into its own project within the Single User Storage. That may be tricky though, as only Fusion Team allows cross-project references which may cause the Move/Copy not to succeed if one exists in single user storage.
Let me know if you can/can't transfer that entire project however (and the reason, if you can't - such as the project does not appear in the transfer dialog).
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 8 of 9
paolo.recchi
Dear @ James.Youmatz
Move the entire folder Autodesk f360 experience is not allowed as I think is not shown between my project folder as I’m not the owner.
Move folder by folder as the same doesn’t work because all the child and relationships between the file get lost.
I will try with the script that you can find on github that makes bakup of all cloud contents it seems work but need a lot of time and block possibilities to use the software during the process and I would try to do it in the night.
I will keep you in touch.
Thank you so much for your time, I hope meanwhile I try with the download you could find a solution.
Thx.
P_
Message 9 of 9
paolo.recchi
I try with the script that you can find on github that makes bakup of all cloud contents it seems work but need a lot of time and block possibilities to use the software during the process and I would try to do it in the night.
Thx.
P_
