help me
help me
ymj4
Message 1 of 1
help me
ymj4
Community Visitor
Community Visitor
2025-05-03 20:10:35,317 - MainProcess(79128) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/yuttong/Library/Logs/autodesk.webdeploy.streamer.log
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x1011f85f0> #
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/resources/buildinfo.json
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2025-05-03 20:10:35,318 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20250214112351
2025-05-03 20:10:35,339 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: ko_KR
2025-05-03 20:10:35,341 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/resources
2025-05-03 20:10:35,342 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to /Volumes/Autodesk Fusion Installer/Install Autodesk Fusion.app/Contents/MacOS/certs.pem
2025-05-03 20:10:35,342 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2025-05-03 20:10:35,344 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2025-05-03 20:10:35,344 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2025-05-03 20:10:35,344 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x1011ec180>, operation=<function multiple_operate at 0x1010e89a0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2025-05-03 20:10:35,344 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2025-05-03 20:10:35,344 - MainProcess(79128) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2025-05-03 20:10:35,345 - MainProcess(79128) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2025-05-03 20:10:35,345 - MainProcess(79128) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2025-05-03 20:10:37,884 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2025-05-03 20:10:40,093 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2025-05-03 20:10:41,001 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/meta/registry_track is created.
2025-05-03 20:10:41,002 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2025-05-03 20:10:41,004 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2025-05-03 20:10:41,005 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2025-05-03 20:10:41,005 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/97e6dd95735340d6ad6e222a520454db/73e72ada57b7480280f...
2025-05-03 20:10:41,036 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:41,037 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:41,037 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:41,037 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2025-05-03 20:10:41,037 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2025-05-03 20:10:41,038 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 59.151.139.210
2025-05-03 20:10:41,076 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2025-05-03 20:10:41,077 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NTkuMTUxLjEzOS4yMTA=
2025-05-03 20:10:41,082 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTI3LjAuMC4x
2025-05-03 20:10:41,082 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2025-05-03 20:10:41,082 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2025-05-03 20:10:41,247 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Streamer version to be installed: 20250214112351
2025-05-03 20:10:41,248 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: skip_precheck file not found on Mac
2025-05-03 20:10:41,248 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2025-05-03 20:10:41,248 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckMacOSHardwareConfig'>, <class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2025-05-03 20:10:41,248 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckMacOSHardwareConfig
2025-05-03 20:10:41,848 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Model Identifier: MacBookPro16,3, System Version: 15.4.1
2025-05-03 20:10:41,848 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.osx.platform - INFO :: Product line: MacBookPro, Generation: 16, Trim: 3, MacOS system major version: 15
2025-05-03 20:10:41,848 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: MacOS hardware configuration is supported
2025-05-03 20:10:41,848 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckMacOSHardwareConfig, Result:- SUCCESS
2025-05-03 20:10:41,848 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2025-05-03 20:10:41,849 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: /Users/yuttong/Library/Application Support/Autodesk
2025-05-03 20:10:41,849 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: /Users/yuttong/Applications
2025-05-03 20:10:41,849 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2025-05-03 20:10:41,849 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2025-05-03 20:10:41,849 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2025-05-03 20:10:41,880 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:41,880 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:41,880 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:42,055 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x101e8fe00>
2025-05-03 20:10:42,055 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2025-05-03 20:10:42,094 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2025-05-03 20:10:42,095 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 59.151.139.210
2025-05-03 20:10:42,095 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2025-05-03 20:10:42,095 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2025-05-03 20:10:42,095 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2025-05-03 20:10:42,095 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2025-05-03 20:10:42,127 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:42,127 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:42,127 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:42,285 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x101ea4410>
2025-05-03 20:10:42,286 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2025-05-03 20:10:42,326 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2025-05-03 20:10:42,327 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 59.151.139.210
2025-05-03 20:10:42,364 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:42,364 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:42,364 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:42,538 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x101e8fec0>
2025-05-03 20:10:42,538 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2025-05-03 20:10:42,538 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2025-05-03 20:10:42,538 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2025-05-03 20:10:42,573 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:42,573 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:42,573 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:42,740 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x101ea4e90>
2025-05-03 20:10:42,740 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2025-05-03 20:10:42,777 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2025-05-03 20:10:42,778 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 59.151.139.210
2025-05-03 20:10:42,778 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2025-05-03 20:10:42,778 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/97e6dd95735340d6ad6e222a520454db/73e72ada57b7480280f...
2025-05-03 20:10:42,810 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:42,810 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:42,811 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:42,977 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2025-05-03 20:10:42,977 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2025-05-03 20:10:42,977 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2025-05-03 20:10:42,977 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2025-05-03 20:10:42,978 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/97e6dd95735340d6ad6e222a520454db/73e72ada57b7480280f...
2025-05-03 20:10:43,008 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,008 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,008 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,172 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 60f29613-2221-4b65-84c6-b229fb5bd7ba
2025-05-03 20:10:43,173 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2601.1.37 for app 73e72ada57b7480280f7a6f4a289729f
2025-05-03 20:10:43,173 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:10:43,174 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2025-05-03 20:10:43,174 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [12, 0]
2025-05-03 20:10:43,174 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version found.
2025-05-03 20:10:43,174 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2025-05-03 20:10:43,177 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7a83ec05160b359b10d8e286bc8d314364cae532
2025-05-03 20:10:43,177 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7a83ec05160b359b10d8e286bc8d314364cae532.js...
2025-05-03 20:10:43,206 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,206 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,207 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,370 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4e0e78909e86eab6f293e68232efc4cd7eb562a5.ta... for package 7a83ec05160b359b10d8e286bc8d314364cae532
2025-05-03 20:10:43,370 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c9bf941b288a066661c1a2c2b80a9fb9ecac464f
2025-05-03 20:10:43,370 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c9bf941b288a066661c1a2c2b80a9fb9ecac464f.js...
2025-05-03 20:10:43,416 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,416 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,416 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,416 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,417 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,417 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,581 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:43,581 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2025-05-03 20:10:43,583 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f50e05a61005c9926a3ab33c1ff418ae1759accf.ta... for package c9bf941b288a066661c1a2c2b80a9fb9ecac464f
2025-05-03 20:10:43,583 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cc2d8953d1ec94840e58b56294447caac2c9154a
2025-05-03 20:10:43,583 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cc2d8953d1ec94840e58b56294447caac2c9154a.js...
2025-05-03 20:10:43,642 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,643 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,643 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,643 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,643 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,643 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,810 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/bc7dae4dd4788ef96555b1cdef23a7358f168780.ta... for package cc2d8953d1ec94840e58b56294447caac2c9154a
2025-05-03 20:10:43,811 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 20bf6b3da0b085016908aef91280a2b73063b79f
2025-05-03 20:10:43,811 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/20bf6b3da0b085016908aef91280a2b73063b79f.js...
2025-05-03 20:10:43,814 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:43,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:43,868 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:43,872 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:43,872 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,054 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:44,301 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d983a021387c947106edb51d809b7db58ced3806.ta... for package 20bf6b3da0b085016908aef91280a2b73063b79f
2025-05-03 20:10:44,301 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b8886a8b11732fe68a79cc47e204ef42dfb598f8
2025-05-03 20:10:44,301 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b8886a8b11732fe68a79cc47e204ef42dfb598f8.js...
2025-05-03 20:10:44,381 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:44,382 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:44,382 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:44,383 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,383 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:44,383 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,425 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:44,555 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:44,556 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: d77c19b80c0a906b40ce91994aab6771d037471b
2025-05-03 20:10:44,556 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d77c19b80c0a906b40ce91994aab6771d037471b.js...
2025-05-03 20:10:44,556 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9aebb67a2fda5a5a2a49c7327b79a3353b794d46.ta... for package b8886a8b11732fe68a79cc47e204ef42dfb598f8
2025-05-03 20:10:44,618 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:44,618 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:44,618 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,619 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:44,619 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:44,619 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,743 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:44,802 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:44,802 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cc3f7031ddf7ef508365fe7cc5e1878a173a0cc6
2025-05-03 20:10:44,803 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9526e85580674cd0243293ef916db5eef38ddeb9.ta... for package d77c19b80c0a906b40ce91994aab6771d037471b
2025-05-03 20:10:44,803 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cc3f7031ddf7ef508365fe7cc5e1878a173a0cc6.js...
2025-05-03 20:10:44,867 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:44,868 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:44,868 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,868 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:44,868 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:44,868 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:44,914 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:45,052 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:45,052 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7952afafb142a620aae46013d38677568398dd90
2025-05-03 20:10:45,053 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7952afafb142a620aae46013d38677568398dd90.js...
2025-05-03 20:10:45,053 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6324bbbf3d4716b2aaf10b5b4f0b275de5560234.ta... for package cc3f7031ddf7ef508365fe7cc5e1878a173a0cc6
2025-05-03 20:10:45,114 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,115 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,115 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,116 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:45,117 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,122 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:45,157 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:45,157 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3cf5730b2d3a53d980cdc34cde2ed9fbfbcf4838.ta... for package cc3f7031ddf7ef508365fe7cc5e1878a173a0cc6
2025-05-03 20:10:45,191 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,191 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,191 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:45,295 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a8cdb54f2855febb5780fcbe34f6224085f33b56
2025-05-03 20:10:45,295 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a8cdb54f2855febb5780fcbe34f6224085f33b56.js...
2025-05-03 20:10:45,298 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:45,337 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,337 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,337 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:45,351 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:45,363 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:45,363 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b8b5266a4b8f1f01826d75f25b9e470cce41e417.ta... for package 7952afafb142a620aae46013d38677568398dd90
2025-05-03 20:10:45,397 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,397 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,397 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:45,508 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: ad0a3a53fd741b08c01e3f1be591ec22350800d0
2025-05-03 20:10:45,508 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ad0a3a53fd741b08c01e3f1be591ec22350800d0.js...
2025-05-03 20:10:45,552 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,552 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,552 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:45,568 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:45,818 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 15a54150c4a05d91d70e42b44a3dd2dfc201e293
2025-05-03 20:10:45,818 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/15a54150c4a05d91d70e42b44a3dd2dfc201e293.js...
2025-05-03 20:10:45,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:45,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:45,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:46,068 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b432afdd7acd862068ca107aac8037d27b987344
2025-05-03 20:10:46,068 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b432afdd7acd862068ca107aac8037d27b987344.js...
2025-05-03 20:10:46,123 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:46,123 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:46,123 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:46,324 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:46,326 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/981d1d37fe4c9e8bb1a77d196793334425583bf8.ta... for package a8cdb54f2855febb5780fcbe34f6224085f33b56
2025-05-03 20:10:46,331 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 393e6e53ffd0ca75558659c09c9c60c4d7ba8cb0
2025-05-03 20:10:46,331 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/393e6e53ffd0ca75558659c09c9c60c4d7ba8cb0.js...
2025-05-03 20:10:46,390 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:46,391 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:46,391 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:46,397 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:46,398 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:46,401 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:46,566 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 27b5e478f67b89296e37cd1e21ab24a8b1f8df51
2025-05-03 20:10:46,566 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/27b5e478f67b89296e37cd1e21ab24a8b1f8df51.js...
2025-05-03 20:10:46,577 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:46,617 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:46,617 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:46,617 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:46,780 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: ea8ddf8ee4fb0e80fb58050f41360eefd03d5c97
2025-05-03 20:10:46,780 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ea8ddf8ee4fb0e80fb58050f41360eefd03d5c97.js...
2025-05-03 20:10:46,832 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:46,832 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:46,832 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,002 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:47,005 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9877e04b1afbf550d0becb3928d588c850b80f63.ta... for package ad0a3a53fd741b08c01e3f1be591ec22350800d0
2025-05-03 20:10:47,018 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 626194620caffed38faf581e3a62767a15c3d300
2025-05-03 20:10:47,018 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/626194620caffed38faf581e3a62767a15c3d300.js...
2025-05-03 20:10:47,059 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,060 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,060 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,073 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,073 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,073 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,231 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:47,246 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b322459c0650dd1ec7c18d8e0a01335133fa5d84
2025-05-03 20:10:47,246 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b322459c0650dd1ec7c18d8e0a01335133fa5d84.js...
2025-05-03 20:10:47,273 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:47,274 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a63c0c719e9ba7ddde52765a3a239bb835723633.ta... for package ad0a3a53fd741b08c01e3f1be591ec22350800d0
2025-05-03 20:10:47,298 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,298 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,298 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,321 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,321 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,321 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,468 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: fd3e7f3d0be189a632e9ebe6bf250da7c8a4daef
2025-05-03 20:10:47,468 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/fd3e7f3d0be189a632e9ebe6bf250da7c8a4daef.js...
2025-05-03 20:10:47,502 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:47,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:47,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d843185da4ce53d33973a66cc0ca2e496d346208.ta... for package 15a54150c4a05d91d70e42b44a3dd2dfc201e293
2025-05-03 20:10:47,510 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,511 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,511 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,545 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,545 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,545 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,605 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:47,606 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7a1bce62d954f9c081de1d02c85fe440038b7f92.ta... for package b432afdd7acd862068ca107aac8037d27b987344
2025-05-03 20:10:47,643 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,643 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,643 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,682 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 745dd2ee81e0553f0309ccfdb91aa7c5dfaab76d
2025-05-03 20:10:47,682 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/745dd2ee81e0553f0309ccfdb91aa7c5dfaab76d.js...
2025-05-03 20:10:47,717 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,717 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,717 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:47,721 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:47,815 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:47,888 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 813dac62217a94df6f86cf14bc8a68b03d384b38
2025-05-03 20:10:47,888 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/813dac62217a94df6f86cf14bc8a68b03d384b38.js...
2025-05-03 20:10:47,936 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:47,936 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:47,936 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:48,248 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 03ae43f7c52418b6f7a5ae8156e431bd25fe316e
2025-05-03 20:10:48,249 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/03ae43f7c52418b6f7a5ae8156e431bd25fe316e.js...
2025-05-03 20:10:48,298 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:48,298 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:48,298 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:48,555 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 67561e330204dfd65059dca3df142387db2c9739
2025-05-03 20:10:48,555 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/67561e330204dfd65059dca3df142387db2c9739.js...
2025-05-03 20:10:48,606 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:48,606 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:48,606 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:48,776 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: d76738750126119043bab089faf3d7ecf5dd98e3
2025-05-03 20:10:48,777 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d76738750126119043bab089faf3d7ecf5dd98e3.js...
2025-05-03 20:10:48,827 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:48,827 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:48,827 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:49,051 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5cb9b880762833acecf1a28fa7ca415a9c236775
2025-05-03 20:10:49,051 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5cb9b880762833acecf1a28fa7ca415a9c236775.js...
2025-05-03 20:10:49,108 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:49,108 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:49,108 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:49,320 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 215401d8b6b9e4041f083b4a13a48df05d5d2b1c
2025-05-03 20:10:49,320 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/215401d8b6b9e4041f083b4a13a48df05d5d2b1c.js...
2025-05-03 20:10:49,377 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:49,378 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:49,378 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:49,573 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 0bc077ddfa67a5c90079a8ca01e9d73f1bdc7674
2025-05-03 20:10:49,573 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/0bc077ddfa67a5c90079a8ca01e9d73f1bdc7674.js...
2025-05-03 20:10:49,633 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:49,633 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:49,633 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:49,805 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9bac64b7ab5cb2c3259b66d4668e51d5883e24cf
2025-05-03 20:10:49,806 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9bac64b7ab5cb2c3259b66d4668e51d5883e24cf.js...
2025-05-03 20:10:49,867 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:49,868 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:49,868 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:50,072 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 767b2bd85d838756f62ab0fe585baf2227b0e50c
2025-05-03 20:10:50,072 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/767b2bd85d838756f62ab0fe585baf2227b0e50c.js...
2025-05-03 20:10:50,124 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:50,124 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:50,124 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:50,326 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8fcf2264616ba7608829493ee2f82fec1fbebaa0
2025-05-03 20:10:50,326 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8fcf2264616ba7608829493ee2f82fec1fbebaa0.js...
2025-05-03 20:10:50,386 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:50,386 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:50,386 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:50,750 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6fb4c70b5f81c6dbef865e2801d7e40b6f90fa96
2025-05-03 20:10:50,751 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6fb4c70b5f81c6dbef865e2801d7e40b6f90fa96.js...
2025-05-03 20:10:50,806 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:50,807 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:50,815 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:51,124 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: d385431040c07681bc9db2f815fa72f301e9639a
2025-05-03 20:10:51,124 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d385431040c07681bc9db2f815fa72f301e9639a.js...
2025-05-03 20:10:51,233 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:51,234 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:51,239 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:51,433 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f7afb6077caddec727bb0adfa0880c255977711c
2025-05-03 20:10:51,434 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f7afb6077caddec727bb0adfa0880c255977711c.js...
2025-05-03 20:10:51,500 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:51,500 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:51,500 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:51,713 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9d71e6b67c797a251eaf28c70411f4c25a86b009
2025-05-03 20:10:51,713 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9d71e6b67c797a251eaf28c70411f4c25a86b009.js...
2025-05-03 20:10:51,777 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:51,778 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:51,778 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:51,964 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 649c3fca1563c4dc3ce54b25526e5bfcae0dc073
2025-05-03 20:10:51,964 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/649c3fca1563c4dc3ce54b25526e5bfcae0dc073.js...
2025-05-03 20:10:52,028 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:52,028 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:52,028 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:52,201 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:10:52,201 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/646f1c9c5bb09212e0964509c2ff3b7c91205b0c.js...
2025-05-03 20:10:52,260 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:52,260 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:52,260 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:52,476 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 986bdef6b399f149148021cc8d3f3be590889965
2025-05-03 20:10:52,476 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/986bdef6b399f149148021cc8d3f3be590889965.js...
2025-05-03 20:10:52,532 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:52,532 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:52,532 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:52,757 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:10:52,758 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4871198a6ba06aa6a1281a06577fbbb32267bd93.js...
2025-05-03 20:10:52,814 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:52,814 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:52,815 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:52,982 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b5d15850ec3ece32729c8ecc1d2953c74a66d04f
2025-05-03 20:10:52,982 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b5d15850ec3ece32729c8ecc1d2953c74a66d04f.js...
2025-05-03 20:10:53,036 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,036 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,036 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:53,228 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 02c39afc214346d54a644d0dacd965b1fa626dea
2025-05-03 20:10:53,228 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/02c39afc214346d54a644d0dacd965b1fa626dea.js...
2025-05-03 20:10:53,287 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,287 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,288 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:53,335 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:53,339 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3d007ec73b2011da49aafb52d87448335d259059.ta... for package b432afdd7acd862068ca107aac8037d27b987344
2025-05-03 20:10:53,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:53,464 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c1e74d27d75284d12514b9c13643ae028f67aa02
2025-05-03 20:10:53,464 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c1e74d27d75284d12514b9c13643ae028f67aa02.js...
2025-05-03 20:10:53,512 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,512 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,512 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:53,563 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:53,671 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:53,671 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/34257cc769c52f02cceaeb2ddfd5868098e5dbd4.ta... for package 393e6e53ffd0ca75558659c09c9c60c4d7ba8cb0
2025-05-03 20:10:53,683 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 34269ac2e3656aca3ac9fbab71ccb0416d6ceb60
2025-05-03 20:10:53,683 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/34269ac2e3656aca3ac9fbab71ccb0416d6ceb60.js...
2025-05-03 20:10:53,739 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,739 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,739 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:53,752 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,752 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,752 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:53,906 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:53,920 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5cb2350321ca27e69c1ecc3f2f3ca560f4b9a0cc
2025-05-03 20:10:53,920 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5cb2350321ca27e69c1ecc3f2f3ca560f4b9a0cc.js...
2025-05-03 20:10:53,971 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:53,971 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:53,971 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:54,148 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:10:54,148 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/981ef6dc129457d3d92859ab30b9729fb1a315cc.js...
2025-05-03 20:10:54,204 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:54,205 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:54,205 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:54,381 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8e477f50ba46ab2c4402869056429a2e7a0b73be
2025-05-03 20:10:54,386 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8e477f50ba46ab2c4402869056429a2e7a0b73be.js...
2025-05-03 20:10:54,439 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:54,439 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:54,439 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:54,613 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:10:54,613 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/15f3e2f221675c40fbfe4ea428b39ff663943393.js...
2025-05-03 20:10:54,667 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:54,667 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:54,668 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:54,682 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:10:54,685 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98c838dbebf3e867faf3f6521286f6352890a1fd.ta... for package 27b5e478f67b89296e37cd1e21ab24a8b1f8df51
2025-05-03 20:10:54,738 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:54,738 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:54,738 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:54,845 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c726ebf44198d6cf8acd81a7e98ae520190d8613
2025-05-03 20:10:54,845 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c726ebf44198d6cf8acd81a7e98ae520190d8613.js...
2025-05-03 20:10:54,903 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:54,903 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:54,903 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:54,911 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:10:55,073 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 006592cb04ddbb1ab057271f96032a85c2f73ec4
2025-05-03 20:10:55,073 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/006592cb04ddbb1ab057271f96032a85c2f73ec4.js...
2025-05-03 20:10:55,138 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:55,139 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:55,139 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:55,311 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7b392d5c8680f5d2d7f70bec830e4ced01bdf82a
2025-05-03 20:10:55,312 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7b392d5c8680f5d2d7f70bec830e4ced01bdf82a.js...
2025-05-03 20:10:55,388 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:55,388 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:55,388 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:55,567 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b32813a03a47f6e54920fd3ffd8403b1ada65cca
2025-05-03 20:10:55,567 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b32813a03a47f6e54920fd3ffd8403b1ada65cca.js...
2025-05-03 20:10:55,636 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:55,636 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:55,637 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:55,831 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 563f8dce65c31ab341889ecebd86af04b483b14b
2025-05-03 20:10:55,831 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/563f8dce65c31ab341889ecebd86af04b483b14b.js...
2025-05-03 20:10:55,889 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:55,889 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:55,889 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:56,066 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dd13ccd9b94b67fc5ece59b9649ca70aa7c0b654
2025-05-03 20:10:56,066 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dd13ccd9b94b67fc5ece59b9649ca70aa7c0b654.js...
2025-05-03 20:10:56,125 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:56,125 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:56,125 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:56,294 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3153506da2dc493886dedf91d78a970f157b197d
2025-05-03 20:10:56,294 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3153506da2dc493886dedf91d78a970f157b197d.js...
2025-05-03 20:10:56,359 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:56,359 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:56,359 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:56,529 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 0c01ea96df0691578f50bffa06aebd3ec0c7b84c
2025-05-03 20:10:56,529 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/0c01ea96df0691578f50bffa06aebd3ec0c7b84c.js...
2025-05-03 20:10:56,590 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:56,590 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:56,590 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:56,756 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3c934ed86c70159cd892944fb653b94455add6f4
2025-05-03 20:10:56,756 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c934ed86c70159cd892944fb653b94455add6f4.js...
2025-05-03 20:10:56,829 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:56,829 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:56,829 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:57,012 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: be5bee1479dcd831b1c6872f8ad8230ea5bbe35b
2025-05-03 20:10:57,012 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/be5bee1479dcd831b1c6872f8ad8230ea5bbe35b.js...
2025-05-03 20:10:57,067 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:10:57,067 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:10:57,067 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:10:57,241 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2025-05-03 20:10:57,241 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7a83ec05160b359b10d8e286bc8d314364cae532
2025-05-03 20:10:57,244 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c9bf941b288a066661c1a2c2b80a9fb9ecac464f
2025-05-03 20:10:57,299 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cc2d8953d1ec94840e58b56294447caac2c9154a
2025-05-03 20:10:57,301 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 20bf6b3da0b085016908aef91280a2b73063b79f
2025-05-03 20:10:57,305 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b8886a8b11732fe68a79cc47e204ef42dfb598f8
2025-05-03 20:10:57,308 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for d77c19b80c0a906b40ce91994aab6771d037471b
2025-05-03 20:10:57,311 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cc3f7031ddf7ef508365fe7cc5e1878a173a0cc6
2025-05-03 20:10:57,327 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7952afafb142a620aae46013d38677568398dd90
2025-05-03 20:10:57,330 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a8cdb54f2855febb5780fcbe34f6224085f33b56
2025-05-03 20:10:57,332 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for ad0a3a53fd741b08c01e3f1be591ec22350800d0
2025-05-03 20:11:03,107 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:03,112 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7ef7da7978bbac7f21b813f646197dd2123e5c26.ta... for package 27b5e478f67b89296e37cd1e21ab24a8b1f8df51
2025-05-03 20:11:03,154 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:03,155 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:03,155 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:03,324 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:03,347 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:03,347 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/48b01c1f6ab165cfbe22e34325c9bb2d93342ef1.ta... for package ea8ddf8ee4fb0e80fb58050f41360eefd03d5c97
2025-05-03 20:11:03,391 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:03,391 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:03,391 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:03,579 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:03,630 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:03,630 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6d334755885ceaa6bd539191dcbfa6a5d843657c.ta... for package 626194620caffed38faf581e3a62767a15c3d300
2025-05-03 20:11:03,672 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:03,672 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:03,672 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:03,846 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:04,340 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:04,343 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4485d3e540e000c963482b4a397f451903bd489b.ta... for package b322459c0650dd1ec7c18d8e0a01335133fa5d84
2025-05-03 20:11:04,385 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:04,386 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:04,386 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:04,568 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:04,665 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:04,665 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4136367fcc0f534e6a184fdac00e17c39ca6ed9a.ta... for package fd3e7f3d0be189a632e9ebe6bf250da7c8a4daef
2025-05-03 20:11:04,703 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:04,703 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:04,703 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:04,872 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:05,335 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:05,336 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cb2f7447ffbe673ff38f1895124cfd048fe16fb1.ta... for package 745dd2ee81e0553f0309ccfdb91aa7c5dfaab76d
2025-05-03 20:11:05,377 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:05,378 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:05,378 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:05,548 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:06,085 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:06,087 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/910e2859217357738fd98cbe2ad87d28568dbee9.ta... for package 745dd2ee81e0553f0309ccfdb91aa7c5dfaab76d
2025-05-03 20:11:06,128 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:06,128 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:06,129 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:06,295 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:06,329 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:06,330 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f01920b3112542fbec39e05cddb563965ff358e4.ta... for package 813dac62217a94df6f86cf14bc8a68b03d384b38
2025-05-03 20:11:06,371 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:06,372 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:06,372 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:06,542 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:06,813 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:06,816 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/afad18fa1659266d71a3ec8de3aa1a45502b9ddb.ta... for package 813dac62217a94df6f86cf14bc8a68b03d384b38
2025-05-03 20:11:06,817 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 15a54150c4a05d91d70e42b44a3dd2dfc201e293
2025-05-03 20:11:06,859 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:06,859 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:06,860 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:07,029 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:07,037 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:07,037 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/143892ccd254422ef29d1d56e5d9757db025adf3.ta... for package 03ae43f7c52418b6f7a5ae8156e431bd25fe316e
2025-05-03 20:11:07,076 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:07,076 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:07,076 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:07,093 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:07,095 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fae312aefdbf7225dd89cf0f2a36c8663e055728.ta... for package 67561e330204dfd65059dca3df142387db2c9739
2025-05-03 20:11:07,131 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:07,132 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:07,132 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:07,250 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:07,305 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:07,896 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:07,897 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/26366af7b45b4f136d99e6b797877c73ffc80c9c.ta... for package d76738750126119043bab089faf3d7ecf5dd98e3
2025-05-03 20:11:07,936 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:07,936 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:07,937 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:08,113 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:08,626 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:08,628 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a6f510c66322ed509ed801eff58855f907b4619b.ta... for package d76738750126119043bab089faf3d7ecf5dd98e3
2025-05-03 20:11:08,670 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:08,670 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:08,670 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:08,831 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:08,841 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:08,842 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6b8e1594df0a8b79312d7a64a1a7ff50a1599881.ta... for package 5cb9b880762833acecf1a28fa7ca415a9c236775
2025-05-03 20:11:08,884 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:08,884 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:08,884 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:09,062 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:10,131 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:10,134 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c5f283ef02a69f332d952a74d4214163bdd370c4.ta... for package 5cb9b880762833acecf1a28fa7ca415a9c236775
2025-05-03 20:11:10,180 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:10,180 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:10,180 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:10,346 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:10,418 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:10,418 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cd2570161ddd01eadd370ff52fcfd925094f8776.ta... for package 215401d8b6b9e4041f083b4a13a48df05d5d2b1c
2025-05-03 20:11:10,460 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:10,461 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:10,461 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:10,896 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:10,900 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/39d99ca1bc3bb2f55bb03c5ac544518702a4ed8b.ta... for package 215401d8b6b9e4041f083b4a13a48df05d5d2b1c
2025-05-03 20:11:10,919 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:10,947 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:10,947 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:10,947 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:11,272 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:11,283 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:11,283 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/95e5fbcecb492491804a006b8ab53caeb9c4fb92.ta... for package 0bc077ddfa67a5c90079a8ca01e9d73f1bdc7674
2025-05-03 20:11:11,324 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:11,324 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:11,324 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:11,498 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:11,586 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:11,586 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3167d3c8f2bae68fb064d40c0b2393a4cc7299da.ta... for package 0bc077ddfa67a5c90079a8ca01e9d73f1bdc7674
2025-05-03 20:11:11,624 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:11,624 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ac3f25dc2637b5531b51e21a7f91af55262dac50.ta... for package 9bac64b7ab5cb2c3259b66d4668e51d5883e24cf
2025-05-03 20:11:11,632 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:11,632 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:11,633 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:11,666 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:11,666 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:11,666 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:11,820 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:11,822 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:11,823 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e884683e88647e534c7750e425efcee3c1547a6a.ta... for package 9bac64b7ab5cb2c3259b66d4668e51d5883e24cf
2025-05-03 20:11:11,873 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:11,873 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:11,873 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:12,133 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:12,308 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:13,504 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:13,506 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/767b2bd85d838756f62ab0fe585baf2227b0e50c.ta... for package 767b2bd85d838756f62ab0fe585baf2227b0e50c
2025-05-03 20:11:13,537 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:13,537 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:13,537 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:14,530 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/Common
2025-05-03 20:11:20,540 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:20,544 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2750037f20a96b4712511b1f1367ea7a5e66d316.ta... for package 8fcf2264616ba7608829493ee2f82fec1fbebaa0
2025-05-03 20:11:20,579 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:20,580 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:20,580 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:20,840 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:21,258 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:21,262 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/071a6e29a919a125de9dcf3f14b7b51d38aad77d.ta... for package 6fb4c70b5f81c6dbef865e2801d7e40b6f90fa96
2025-05-03 20:11:21,263 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b432afdd7acd862068ca107aac8037d27b987344
2025-05-03 20:11:21,264 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:21,265 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9a3a1fb951a872c8f3631f7aa69a57315361d82c.ta... for package d385431040c07681bc9db2f815fa72f301e9639a
2025-05-03 20:11:21,279 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 393e6e53ffd0ca75558659c09c9c60c4d7ba8cb0
2025-05-03 20:11:21,282 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 27b5e478f67b89296e37cd1e21ab24a8b1f8df51
2025-05-03 20:11:21,313 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:21,313 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:21,314 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:21,316 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:21,316 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:21,316 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:21,415 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for ea8ddf8ee4fb0e80fb58050f41360eefd03d5c97
2025-05-03 20:11:21,417 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 626194620caffed38faf581e3a62767a15c3d300
2025-05-03 20:11:21,418 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b322459c0650dd1ec7c18d8e0a01335133fa5d84
2025-05-03 20:11:21,419 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for fd3e7f3d0be189a632e9ebe6bf250da7c8a4daef
2025-05-03 20:11:21,421 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 745dd2ee81e0553f0309ccfdb91aa7c5dfaab76d
2025-05-03 20:11:21,425 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 813dac62217a94df6f86cf14bc8a68b03d384b38
2025-05-03 20:11:21,427 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 03ae43f7c52418b6f7a5ae8156e431bd25fe316e
2025-05-03 20:11:21,435 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 67561e330204dfd65059dca3df142387db2c9739
2025-05-03 20:11:21,436 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package d76738750126119043bab089faf3d7ecf5dd98e3
2025-05-03 20:11:21,437 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action a92c95fa064f43089136f50437f73d22(UPDATE_IDSDK_CONFIG)
2025-05-03 20:11:21,437 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Update config ssoServer property
2025-05-03 20:11:21,437 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Found Configuration file : /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/CONFIG/AdskIdentityManagerInstall.config
2025-05-03 20:11:21,437 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Configuration updated successfully
2025-05-03 20:11:21,437 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package d76738750126119043bab089faf3d7ecf5dd98e3
2025-05-03 20:11:21,438 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for d76738750126119043bab089faf3d7ecf5dd98e3
2025-05-03 20:11:21,443 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5cb9b880762833acecf1a28fa7ca415a9c236775
2025-05-03 20:11:21,446 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 215401d8b6b9e4041f083b4a13a48df05d5d2b1c
2025-05-03 20:11:21,448 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 0bc077ddfa67a5c90079a8ca01e9d73f1bdc7674
2025-05-03 20:11:21,559 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:21,560 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:22,230 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:22,231 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2f2dec4c0ba3f59fd5d1520e6e7f941628aadb37.ta... for package f7afb6077caddec727bb0adfa0880c255977711c
2025-05-03 20:11:22,269 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:22,270 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:22,270 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:22,451 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:23,123 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:23,124 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/bb0c6716bf837a0691a49069aa762d8bc43d78bb.ta... for package 9d71e6b67c797a251eaf28c70411f4c25a86b009
2025-05-03 20:11:23,157 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:23,157 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:23,157 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:23,431 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:28,042 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:28,047 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/41c1720f5462c0c2bd938544ee578ae0f9933903.ta... for package 9d71e6b67c797a251eaf28c70411f4c25a86b009
2025-05-03 20:11:28,082 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:28,082 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:28,082 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:28,336 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:28,415 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:28,415 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8fd0eb641d95649687a9350accbc7b74236cb167.ta... for package 649c3fca1563c4dc3ce54b25526e5bfcae0dc073
2025-05-03 20:11:28,446 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:28,446 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:28,446 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:28,704 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:11:29,892 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:11:29,894 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:11:29,934 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:11:29,935 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:11:29,935 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:11:30,187 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:12:15,727 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:12:15,731 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3797b1f977237baa82d77f7e3a4110f629982db0.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:12:15,832 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:12:15,833 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:12:15,833 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:12:16,139 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:12:16,282 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:12:16,282 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/eb823f1be461f47ab6e39f34a8b641014eee8f0f.ta... for package 986bdef6b399f149148021cc8d3f3be590889965
2025-05-03 20:12:16,444 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:12:16,444 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:12:16,445 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:12:16,813 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:12:20,874 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:12:20,878 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/da7abe31605211f54750b955741b6e3b0461e0eb.ta... for package 986bdef6b399f149148021cc8d3f3be590889965
2025-05-03 20:12:20,949 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:12:20,950 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:12:20,950 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:12:21,326 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:12:21,477 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:12:21,478 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:12:21,551 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:12:21,551 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:12:21,551 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:12:21,927 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:05,823 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:05,832 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d1bb6315ad0c4ae7980917abf564ae8fada1a455.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:05,907 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:05,907 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:05,907 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:06,210 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:06,595 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:06,596 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/be0dccdd523234222e81fb3360f22c20f7d9d97c.ta... for package b5d15850ec3ece32729c8ecc1d2953c74a66d04f
2025-05-03 20:13:06,635 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:06,635 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:06,635 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:07,086 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:09,392 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:09,393 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b8ce2f7bf659bab550577139fbb6ed040c2b3cf8.ta... for package 02c39afc214346d54a644d0dacd965b1fa626dea
2025-05-03 20:13:09,425 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:09,425 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:09,426 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:09,756 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:15,874 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:15,882 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0be6445f7305e10f7b1c3954006bd0e34bf5b81b.ta... for package 02c39afc214346d54a644d0dacd965b1fa626dea
2025-05-03 20:13:15,915 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:15,915 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:15,915 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:16,140 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:16,562 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:16,563 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ece52a2e6a11eb59226ebd996d4c3adabc23c5cc.ta... for package c1e74d27d75284d12514b9c13643ae028f67aa02
2025-05-03 20:13:16,595 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:16,595 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:16,595 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:16,925 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:18,634 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:18,637 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4404a97a875dd9d59da0320513eaa1d026457f1a.ta... for package c1e74d27d75284d12514b9c13643ae028f67aa02
2025-05-03 20:13:18,673 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:18,673 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:18,673 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:18,959 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:18,963 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:18,963 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/25259f5b906b5219e8106123fb9b0d72d7ea00cd.ta... for package 34269ac2e3656aca3ac9fbab71ccb0416d6ceb60
2025-05-03 20:13:19,005 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:19,006 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:19,006 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:19,187 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:20,546 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:20,549 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/99c00152b959b8122ab049c8ab2643bcbcb9e555.ta... for package 34269ac2e3656aca3ac9fbab71ccb0416d6ceb60
2025-05-03 20:13:20,582 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:20,582 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:20,582 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:20,744 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:20,763 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:20,763 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d66a36753b046c462bde1a4e97f4fbe66e0319c2.ta... for package 5cb2350321ca27e69c1ecc3f2f3ca560f4b9a0cc
2025-05-03 20:13:20,812 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:20,813 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:20,813 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:21,205 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:22,133 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:22,138 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/75fcd753597cf50a5df369c64462b472b5607b97.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:22,170 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:22,170 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:22,170 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:22,382 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:37,103 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:37,109 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:37,167 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:37,167 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:37,168 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:37,243 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:37,252 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/879e4456e7ec49082c6fb7a1250a4aebd0112375.ta... for package 8e477f50ba46ab2c4402869056429a2e7a0b73be
2025-05-03 20:13:37,252 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 9bac64b7ab5cb2c3259b66d4668e51d5883e24cf
2025-05-03 20:13:37,253 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2025-05-03 20:13:37,253 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2025-05-03 20:13:37,254 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 36d909d4c5304fc2a6a47bbb9116f50e(REMOVE_STREAMING_SESSION) was not in registry
2025-05-03 20:13:37,254 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 9bac64b7ab5cb2c3259b66d4668e51d5883e24cf
2025-05-03 20:13:37,256 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9bac64b7ab5cb2c3259b66d4668e51d5883e24cf
2025-05-03 20:13:37,290 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:37,290 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:37,290 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:37,449 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:37,486 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:37,763 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2025-05-03 20:13:37,763 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:37,811 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:37,811 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:37,811 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:37,905 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 767b2bd85d838756f62ab0fe585baf2227b0e50c
2025-05-03 20:13:37,905 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2025-05-03 20:13:37,905 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2025-05-03 20:13:37,909 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Executing: "/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/MaterialLibraryMigrator" "migratecache" "/Users/yuttong/Library/Application Support/Autodesk/Common/Material Library"
2025-05-03 20:13:38,111 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:38,154 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimTemplate10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimTemplate10.xml'
2025-05-03 20:13:38,154 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:38,155 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:38,155 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:38,158 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:38,159 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMoldingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMoldingUI10.xml'... IGNORING
2025-05-03 20:13:38,159 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimBase10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimBase10.xml'... IGNORING
2025-05-03 20:13:38,160 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimBaseUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimBaseUI10.xml'... IGNORING
2025-05-03 20:13:38,160 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFD10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFD10.xml'... IGNORING
2025-05-03 20:13:38,161 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDAttributes10.xml'... IGNORING
2025-05-03 20:13:38,161 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,161 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDController10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDController10.xml'... IGNORING
2025-05-03 20:13:38,162 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCFDUI10.xml'... IGNORING
2025-05-03 20:13:38,162 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCommon10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCommon10.xml'... IGNORING
2025-05-03 20:13:38,162 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCommonUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimCommonUI10.xml'... IGNORING
2025-05-03 20:13:38,162 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimDesignVariations10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimDesignVariations10.xml'... IGNORING
2025-05-03 20:13:38,163 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimDesignVariationsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimDesignVariationsUI10.xml'... IGNORING
2025-05-03 20:13:38,164 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFEACSObjects10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFEACSObjects10.xml'... IGNORING
2025-05-03 20:13:38,168 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFEACSObjectsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFEACSObjectsUI10.xml'... IGNORING
2025-05-03 20:13:38,168 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFluidDynamics10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFluidDynamics10.xml'... IGNORING
2025-05-03 20:13:38,169 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFluidDynamicsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimFluidDynamicsUI10.xml'... IGNORING
2025-05-03 20:13:38,176 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLinearAnalysisController10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLinearAnalysisController10.xml'... IGNORING
2025-05-03 20:13:38,177 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:38,180 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:38,181 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:38,181 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLinearStaticStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLinearStaticStress10.xml'... IGNORING
2025-05-03 20:13:38,182 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:38,187 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 123, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 372, in <lambda>
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 673, in _extractpackage
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2269, in extractall
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/tar_package_record.py", line 78, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2336, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2332, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2417, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2446, in makedir
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:38,192 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLinearStaticStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLinearStaticStressUI10.xml'... IGNORING
2025-05-03 20:13:38,204 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLMVProducer10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimLMVProducer10.xml'... IGNORING
2025-05-03 20:13:38,208 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimPostProcessing10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimPostProcessing10.xml'... IGNORING
2025-05-03 20:13:38,212 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimPostProcessingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimPostProcessingUI10.xml'... IGNORING
2025-05-03 20:13:38,224 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimStructuralAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimStructuralAttributes10.xml'... IGNORING
2025-05-03 20:13:38,227 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimStructuralAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimStructuralAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,232 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimTemplate10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimTemplate10.xml'... IGNORING
2025-05-03 20:13:38,241 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimTemplateUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimTemplateUI10.xml'... IGNORING
2025-05-03 20:13:38,245 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalAttributes10.xml'... IGNORING
2025-05-03 20:13:38,249 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,254 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalSteady10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalSteady10.xml'... IGNORING
2025-05-03 20:13:38,262 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalSteadyUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalSteadyUI10.xml'... IGNORING
2025-05-03 20:13:38,263 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalStress10.xml'... IGNORING
2025-05-03 20:13:38,264 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalStressUI10.xml'... IGNORING
2025-05-03 20:13:38,264 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalTransient10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalTransient10.xml'... IGNORING
2025-05-03 20:13:38,265 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalTransientUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimThermalTransientUI10.xml'... IGNORING
2025-05-03 20:13:38,266 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimTranslator10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/SimTranslator10.xml'... IGNORING
2025-05-03 20:13:38,267 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:38,268 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/InjectionMoldingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/InjectionMoldingUI10.xml'... IGNORING
2025-05-03 20:13:38,269 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimBase10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimBase10.xml'... IGNORING
2025-05-03 20:13:38,269 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimBaseUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimBaseUI10.xml'... IGNORING
2025-05-03 20:13:38,270 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimCommon10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimCommon10.xml'... IGNORING
2025-05-03 20:13:38,271 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimCommonUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimCommonUI10.xml'... IGNORING
2025-05-03 20:13:38,272 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimDesignVariations10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimDesignVariations10.xml'... IGNORING
2025-05-03 20:13:38,273 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimDesignVariationsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimDesignVariationsUI10.xml'... IGNORING
2025-05-03 20:13:38,273 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFEACSObjects10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFEACSObjects10.xml'... IGNORING
2025-05-03 20:13:38,273 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFEACSObjectsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFEACSObjectsUI10.xml'... IGNORING
2025-05-03 20:13:38,273 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFluidDynamics10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFluidDynamics10.xml'... IGNORING
2025-05-03 20:13:38,274 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFluidDynamicsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimFluidDynamicsUI10.xml'... IGNORING
2025-05-03 20:13:38,274 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLinearAnalysisController10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLinearAnalysisController10.xml'... IGNORING
2025-05-03 20:13:38,274 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLinearStaticStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLinearStaticStress10.xml'... IGNORING
2025-05-03 20:13:38,274 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLinearStaticStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLinearStaticStressUI10.xml'... IGNORING
2025-05-03 20:13:38,275 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLMVProducer10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimLMVProducer10.xml'... IGNORING
2025-05-03 20:13:38,275 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimPostProcessing10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimPostProcessing10.xml'... IGNORING
2025-05-03 20:13:38,275 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimPostProcessingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimPostProcessingUI10.xml'... IGNORING
2025-05-03 20:13:38,275 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimStructuralAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimStructuralAttributes10.xml'... IGNORING
2025-05-03 20:13:38,276 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimStructuralAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimStructuralAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,276 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimTemplate10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimTemplate10.xml'... IGNORING
2025-05-03 20:13:38,276 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimTemplateUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimTemplateUI10.xml'... IGNORING
2025-05-03 20:13:38,277 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalAttributes10.xml'... IGNORING
2025-05-03 20:13:38,278 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,278 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalSteady10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalSteady10.xml'... IGNORING
2025-05-03 20:13:38,278 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalSteadyUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalSteadyUI10.xml'... IGNORING
2025-05-03 20:13:38,279 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalStress10.xml'... IGNORING
2025-05-03 20:13:38,279 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalStressUI10.xml'... IGNORING
2025-05-03 20:13:38,280 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalTransient10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalTransient10.xml'... IGNORING
2025-05-03 20:13:38,280 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalTransientUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimThermalTransientUI10.xml'... IGNORING
2025-05-03 20:13:38,280 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimTranslator10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/en-US/SimTranslator10.xml'... IGNORING
2025-05-03 20:13:38,280 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:38,281 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/InjectionMoldingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/InjectionMoldingUI10.xml'... IGNORING
2025-05-03 20:13:38,281 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimBase10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimBase10.xml'... IGNORING
2025-05-03 20:13:38,281 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimBaseUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimBaseUI10.xml'... IGNORING
2025-05-03 20:13:38,281 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimCommon10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimCommon10.xml'... IGNORING
2025-05-03 20:13:38,281 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimCommonUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimCommonUI10.xml'... IGNORING
2025-05-03 20:13:38,281 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimDesignVariations10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimDesignVariations10.xml'... IGNORING
2025-05-03 20:13:38,282 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimDesignVariationsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimDesignVariationsUI10.xml'... IGNORING
2025-05-03 20:13:38,282 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFEACSObjects10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFEACSObjects10.xml'... IGNORING
2025-05-03 20:13:38,282 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFEACSObjectsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFEACSObjectsUI10.xml'... IGNORING
2025-05-03 20:13:38,282 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFluidDynamics10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFluidDynamics10.xml'... IGNORING
2025-05-03 20:13:38,282 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFluidDynamicsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimFluidDynamicsUI10.xml'... IGNORING
2025-05-03 20:13:38,283 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLinearAnalysisController10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLinearAnalysisController10.xml'... IGNORING
2025-05-03 20:13:38,283 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLinearStaticStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLinearStaticStress10.xml'... IGNORING
2025-05-03 20:13:38,283 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLinearStaticStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLinearStaticStressUI10.xml'... IGNORING
2025-05-03 20:13:38,283 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLMVProducer10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimLMVProducer10.xml'... IGNORING
2025-05-03 20:13:38,283 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimPostProcessing10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimPostProcessing10.xml'... IGNORING
2025-05-03 20:13:38,283 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimPostProcessingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimPostProcessingUI10.xml'... IGNORING
2025-05-03 20:13:38,284 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimStructuralAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimStructuralAttributes10.xml'... IGNORING
2025-05-03 20:13:38,284 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimStructuralAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimStructuralAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,284 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimTemplate10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimTemplate10.xml'... IGNORING
2025-05-03 20:13:38,284 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimTemplateUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimTemplateUI10.xml'... IGNORING
2025-05-03 20:13:38,284 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalAttributes10.xml'... IGNORING
2025-05-03 20:13:38,285 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,285 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalSteady10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalSteady10.xml'... IGNORING
2025-05-03 20:13:38,286 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalSteadyUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalSteadyUI10.xml'... IGNORING
2025-05-03 20:13:38,287 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalStress10.xml'... IGNORING
2025-05-03 20:13:38,288 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalStressUI10.xml'... IGNORING
2025-05-03 20:13:38,288 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalTransient10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalTransient10.xml'... IGNORING
2025-05-03 20:13:38,289 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalTransientUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimThermalTransientUI10.xml'... IGNORING
2025-05-03 20:13:38,289 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimTranslator10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/es-ES/SimTranslator10.xml'... IGNORING
2025-05-03 20:13:38,290 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:38,290 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/InjectionMoldingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/InjectionMoldingUI10.xml'... IGNORING
2025-05-03 20:13:38,290 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimBase10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimBase10.xml'... IGNORING
2025-05-03 20:13:38,290 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimBaseUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimBaseUI10.xml'... IGNORING
2025-05-03 20:13:38,291 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFD10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFD10.xml'... IGNORING
2025-05-03 20:13:38,291 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDAttributes10.xml'... IGNORING
2025-05-03 20:13:38,291 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,291 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDController10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDController10.xml'... IGNORING
2025-05-03 20:13:38,292 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCFDUI10.xml'... IGNORING
2025-05-03 20:13:38,293 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCommon10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCommon10.xml'... IGNORING
2025-05-03 20:13:38,294 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCommonUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimCommonUI10.xml'... IGNORING
2025-05-03 20:13:38,294 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimDesignVariations10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimDesignVariations10.xml'... IGNORING
2025-05-03 20:13:38,294 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimDesignVariationsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimDesignVariationsUI10.xml'... IGNORING
2025-05-03 20:13:38,294 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFEACSObjects10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFEACSObjects10.xml'... IGNORING
2025-05-03 20:13:38,295 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFEACSObjectsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFEACSObjectsUI10.xml'... IGNORING
2025-05-03 20:13:38,296 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFluidDynamics10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFluidDynamics10.xml'... IGNORING
2025-05-03 20:13:38,297 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFluidDynamicsUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimFluidDynamicsUI10.xml'... IGNORING
2025-05-03 20:13:38,297 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLinearAnalysisController10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLinearAnalysisController10.xml'... IGNORING
2025-05-03 20:13:38,298 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLinearStaticStress10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLinearStaticStress10.xml'... IGNORING
2025-05-03 20:13:38,298 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLinearStaticStressUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLinearStaticStressUI10.xml'... IGNORING
2025-05-03 20:13:38,299 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLMVProducer10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimLMVProducer10.xml'... IGNORING
2025-05-03 20:13:38,299 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimPostProcessing10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimPostProcessing10.xml'... IGNORING
2025-05-03 20:13:38,299 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimPostProcessingUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimPostProcessingUI10.xml'... IGNORING
2025-05-03 20:13:38,299 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimStructuralAttributes10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimStructuralAttributes10.xml'... IGNORING
2025-05-03 20:13:38,300 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimStructuralAttributesUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimStructuralAttributesUI10.xml'... IGNORING
2025-05-03 20:13:38,300 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimTemplate10.xml
2025-05-03 20:13:38,300 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 123, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 372, in <lambda>
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 673, in _extractpackage
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2269, in extractall
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/tar_package_record.py", line 78, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2336, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2332, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2415, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2461, in makefile
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/fr-FR/SimTemplate10.xml'
2025-05-03 20:13:40,028 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:40,052 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libmodlr.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libmodlr.dylib'
2025-05-03 20:13:40,053 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:40,053 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:40,053 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:40,054 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:40,054 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/MacOS/AcadDM17: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/MacOS/AcadDM17'... IGNORING
2025-05-03 20:13:40,055 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_0.metallib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_0.metallib'... IGNORING
2025-05-03 20:13:40,055 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_1.metallib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_1.metallib'... IGNORING
2025-05-03 20:13:40,055 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_6.metallib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_6.metallib'... IGNORING
2025-05-03 20:13:40,057 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_7.metallib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_7.metallib'... IGNORING
2025-05-03 20:13:40,058 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_8.metallib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_8.metallib'... IGNORING
2025-05-03 20:13:40,058 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_9.metallib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/AcadDM_Core2D_Metal_9.metallib'... IGNORING
2025-05-03 20:13:40,058 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/action-macros.inl: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/action-macros.inl'... IGNORING
2025-05-03 20:13:40,060 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth.fx'... IGNORING
2025-05-03 20:13:40,061 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth.metalshader'... IGNORING
2025-05-03 20:13:40,061 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth.ogsfx'... IGNORING
2025-05-03 20:13:40,061 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/depth_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,061 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/dmsolid.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/dmsolid.fx'... IGNORING
2025-05-03 20:13:40,062 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/dmsolid.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/dmsolid.ogsfx'... IGNORING
2025-05-03 20:13:40,062 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/dmsolid_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/dmsolid_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,062 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch.fx'... IGNORING
2025-05-03 20:13:40,062 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch.metalshader'... IGNORING
2025-05-03 20:13:40,063 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch.ogsfx'... IGNORING
2025-05-03 20:13:40,063 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/gooch_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,063 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa.fx'... IGNORING
2025-05-03 20:13:40,063 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa.metalshader'... IGNORING
2025-05-03 20:13:40,064 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa.ogsfx'... IGNORING
2025-05-03 20:13:40,065 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineaa_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,065 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow.fx'... IGNORING
2025-05-03 20:13:40,065 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow.metalshader'... IGNORING
2025-05-03 20:13:40,065 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow.ogsfx'... IGNORING
2025-05-03 20:13:40,066 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineglow_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,066 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineinstanceaa.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineinstanceaa.metalshader'... IGNORING
2025-05-03 20:13:40,066 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineinstanceaa_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/lineinstanceaa_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,067 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/OGSMetal.h: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/OGSMetal.h'... IGNORING
2025-05-03 20:13:40,067 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong.fx'... IGNORING
2025-05-03 20:13:40,067 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong.metalshader'... IGNORING
2025-05-03 20:13:40,067 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong.ogsfx'... IGNORING
2025-05-03 20:13:40,068 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/phong_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,068 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow.fx'... IGNORING
2025-05-03 20:13:40,068 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow.metalshader'... IGNORING
2025-05-03 20:13:40,068 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow.ogsfx'... IGNORING
2025-05-03 20:13:40,069 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/pointglow_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,069 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow.fx'... IGNORING
2025-05-03 20:13:40,069 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow.metalshader'... IGNORING
2025-05-03 20:13:40,070 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow.ogsfx'... IGNORING
2025-05-03 20:13:40,070 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/shadow_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,070 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt.fx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt.fx'... IGNORING
2025-05-03 20:13:40,070 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt.metalshader'... IGNORING
2025-05-03 20:13:40,071 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt.ogsfx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt.ogsfx'... IGNORING
2025-05-03 20:13:40,071 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt_preprocessed.metalshader: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Resources/textdt_preprocessed.metalshader'... IGNORING
2025-05-03 20:13:40,071 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/_CodeSignature/CodeResources: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/_CodeSignature/CodeResources'... IGNORING
2025-05-03 20:13:40,071 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcFusPersSubentNaming.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcFusPersSubentNaming.dylib'... IGNORING
2025-05-03 20:13:40,072 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AIRMAX/libtbb.12.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AIRMAX/libtbb.12.dylib'... IGNORING
2025-05-03 20:13:40,072 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/fontEngineUtil17.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/fontEngineUtil17.dylib'... IGNORING
2025-05-03 20:13:40,072 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/ftfont17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/ftfont17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:40,073 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/ftfont17.bundle/Contents/MacOS/ftfont17: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/ftfont17.bundle/Contents/MacOS/ftfont17'... IGNORING
2025-05-03 20:13:40,073 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/ftfont17.bundle/Contents/_CodeSignature/CodeResources: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/ftfont17.bundle/Contents/_CodeSignature/CodeResources'... IGNORING
2025-05-03 20:13:40,073 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAcCoreViewProxy.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAcCoreViewProxy.dylib'... IGNORING
2025-05-03 20:13:40,073 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAcFdStringTable.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAcFdStringTable.dylib'... IGNORING
2025-05-03 20:13:40,073 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAGQ.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAGQ.dylib'... IGNORING
2025-05-03 20:13:40,074 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAutoDimensionEngine.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libAutoDimensionEngine.dylib'... IGNORING
2025-05-03 20:13:40,074 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libDrawingViewCompute.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/FusDoc/libDrawingViewCompute.dylib'... IGNORING
2025-05-03 20:13:40,074 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/heidi17.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/heidi17.dylib'... IGNORING
2025-05-03 20:13:40,074 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/hlr17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/hlr17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:40,075 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/hlr17.bundle/Contents/MacOS/hlr17: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/hlr17.bundle/Contents/MacOS/hlr17'... IGNORING
2025-05-03 20:13:40,075 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/hlr17.bundle/Contents/_CodeSignature/CodeResources: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/hlr17.bundle/Contents/_CodeSignature/CodeResources'... IGNORING
2025-05-03 20:13:40,075 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcBol.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcBol.dylib'... IGNORING
2025-05-03 20:13:40,076 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libaccore.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libaccore.dylib'... IGNORING
2025-05-03 20:13:40,076 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libacdb.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libacdb.dylib'... IGNORING
2025-05-03 20:13:40,076 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcDrawBridge.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcDrawBridge.dylib'... IGNORING
2025-05-03 20:13:40,077 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcDs.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcDs.dylib'... IGNORING
2025-05-03 20:13:40,077 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libacfirst.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libacfirst.dylib'... IGNORING
2025-05-03 20:13:40,077 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcGe230.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcGe230.dylib'... IGNORING
2025-05-03 20:13:40,078 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcGeX230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcGeX230A.dylib'... IGNORING
2025-05-03 20:13:40,078 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcGradient.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcGradient.dylib'... IGNORING
2025-05-03 20:13:40,078 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcIPC.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcIPC.dylib'... IGNORING
2025-05-03 20:13:40,079 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcLineType.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcLineType.dylib'... IGNORING
2025-05-03 20:13:40,079 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcPal.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcPal.dylib'... IGNORING
2025-05-03 20:13:40,079 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcPathMapping.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcPathMapping.dylib'... IGNORING
2025-05-03 20:13:40,079 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcUt.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAcUt.dylib'... IGNORING
2025-05-03 20:13:40,079 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdCoreUnits-16.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdCoreUnits-16.dylib'... IGNORING
2025-05-03 20:13:40,080 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdCoreUnitsUI-16.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdCoreUnitsUI-16.dylib'... IGNORING
2025-05-03 20:13:40,080 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdFolderWatch.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdFolderWatch.dylib'... IGNORING
2025-05-03 20:13:40,080 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdHostableUi.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdHostableUi.dylib'... IGNORING
2025-05-03 20:13:40,081 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdImaging.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdImaging.dylib'... IGNORING
2025-05-03 20:13:40,081 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdIntImgServices.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdIntImgServices.dylib'... IGNORING
2025-05-03 20:13:40,081 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdMaterialUI-16.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdMaterialUI-16.dylib'... IGNORING
2025-05-03 20:13:40,082 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_core-6_1.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_core-6_1.dylib'... IGNORING
2025-05-03 20:13:40,082 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_data-6_1.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_data-6_1.dylib'... IGNORING
2025-05-03 20:13:40,082 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_service_opczip-6_1.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_service_opczip-6_1.dylib'... IGNORING
2025-05-03 20:13:40,082 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_toolkit-6_1.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadp_toolkit-6_1.dylib'... IGNORING
2025-05-03 20:13:40,083 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadskassetapi_new-16.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libadskassetapi_new-16.dylib'... IGNORING
2025-05-03 20:13:40,083 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdUICore-16.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdUICore-16.dylib'... IGNORING
2025-05-03 20:13:40,083 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdUtil-16.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libAdUtil-16.dylib'... IGNORING
2025-05-03 20:13:40,083 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMahl230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMahl230A.dylib'... IGNORING
2025-05-03 20:13:40,083 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMbase230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMbase230A.dylib'... IGNORING
2025-05-03 20:13:40,084 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMblnd230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMblnd230A.dylib'... IGNORING
2025-05-03 20:13:40,084 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMbool230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMbool230A.dylib'... IGNORING
2025-05-03 20:13:40,084 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMcovr230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMcovr230A.dylib'... IGNORING
2025-05-03 20:13:40,085 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMcstr230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMcstr230A.dylib'... IGNORING
2025-05-03 20:13:40,085 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMct230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMct230A.dylib'... IGNORING
2025-05-03 20:13:40,085 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMdatax230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMdatax230A.dylib'... IGNORING
2025-05-03 20:13:40,085 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMdefm230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMdefm230A.dylib'... IGNORING
2025-05-03 20:13:40,086 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMeulr230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMeulr230A.dylib'... IGNORING
2025-05-03 20:13:40,086 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMfct230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMfct230A.dylib'... IGNORING
2025-05-03 20:13:40,086 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMfrec230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMfrec230A.dylib'... IGNORING
2025-05-03 20:13:40,086 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMga230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMga230A.dylib'... IGNORING
2025-05-03 20:13:40,087 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMheal230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMheal230A.dylib'... IGNORING
2025-05-03 20:13:40,087 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMimport230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMimport230A.dylib'... IGNORING
2025-05-03 20:13:40,087 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMintr230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMintr230A.dylib'... IGNORING
2025-05-03 20:13:40,088 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMkern230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMkern230A.dylib'... IGNORING
2025-05-03 20:13:40,088 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMlaw230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMlaw230A.dylib'... IGNORING
2025-05-03 20:13:40,088 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMlop230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMlop230A.dylib'... IGNORING
2025-05-03 20:13:40,088 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMlopt230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMlopt230A.dylib'... IGNORING
2025-05-03 20:13:40,088 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMnpch230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMnpch230A.dylib'... IGNORING
2025-05-03 20:13:40,089 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMofst230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMofst230A.dylib'... IGNORING
2025-05-03 20:13:40,089 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMoper230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMoper230A.dylib'... IGNORING
2025-05-03 20:13:40,090 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMpid230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMpid230A.dylib'... IGNORING
2025-05-03 20:13:40,090 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMrbase230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMrbase230A.dylib'... IGNORING
2025-05-03 20:13:40,090 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMrbi230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMrbi230A.dylib'... IGNORING
2025-05-03 20:13:40,090 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMrem230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMrem230A.dylib'... IGNORING
2025-05-03 20:13:40,091 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMsasm230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMsasm230A.dylib'... IGNORING
2025-05-03 20:13:40,091 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMsbap230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMsbap230A.dylib'... IGNORING
2025-05-03 20:13:40,091 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMsbool230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMsbool230A.dylib'... IGNORING
2025-05-03 20:13:40,091 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMshl230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMshl230A.dylib'... IGNORING
2025-05-03 20:13:40,092 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMskin230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMskin230A.dylib'... IGNORING
2025-05-03 20:13:40,092 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMswp230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMswp230A.dylib'... IGNORING
2025-05-03 20:13:40,092 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMtopt230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMtopt230A.dylib'... IGNORING
2025-05-03 20:13:40,093 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMtwk230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMtwk230A.dylib'... IGNORING
2025-05-03 20:13:40,093 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMufld230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMufld230A.dylib'... IGNORING
2025-05-03 20:13:40,093 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMweld230A.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libASMweld230A.dylib'... IGNORING
2025-05-03 20:13:40,094 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libatlast.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libatlast.dylib'... IGNORING
2025-05-03 20:13:40,094 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libaxdbUtilities.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libaxdbUtilities.dylib'... IGNORING
2025-05-03 20:13:40,094 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libCocoaAPI.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libCocoaAPI.dylib'... IGNORING
2025-05-03 20:13:40,095 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:40,095 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libdvtk.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libdvtk.dylib'... IGNORING
2025-05-03 20:13:40,095 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:40,095 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:40,096 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgelib.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgelib.dylib'... IGNORING
2025-05-03 20:13:40,097 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgelibx.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgelibx.dylib'... IGNORING
2025-05-03 20:13:40,098 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgenreg.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgenreg.dylib'... IGNORING
2025-05-03 20:13:40,098 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_com.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_com.dylib'... IGNORING
2025-05-03 20:13:40,099 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libge_kern.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libge_kern.dylib'... IGNORING
2025-05-03 20:13:40,099 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_load.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_load.dylib'... IGNORING
2025-05-03 20:13:40,100 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_math.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_math.dylib'... IGNORING
2025-05-03 20:13:40,100 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_page.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libGe_page.dylib'... IGNORING
2025-05-03 20:13:40,100 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgs.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libgs.dylib'... IGNORING
2025-05-03 20:13:40,100 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libicudata.70.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libicudata.70.dylib'... IGNORING
2025-05-03 20:13:40,101 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libicuuc.70.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libicuuc.70.dylib'... IGNORING
2025-05-03 20:13:40,101 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libJsonCpp.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libJsonCpp.dylib'... IGNORING
2025-05-03 20:13:40,101 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libMgMdfModel.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libMgMdfModel.dylib'... IGNORING
2025-05-03 20:13:40,102 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libMgMdfParser.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libMgMdfParser.dylib'... IGNORING
2025-05-03 20:13:40,102 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libmmsdk.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libmmsdk.dylib'... IGNORING
2025-05-03 20:13:40,102 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libmodlr.dylib
2025-05-03 20:13:40,103 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 123, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 372, in <lambda>
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 673, in _extractpackage
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2269, in extractall
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/tar_package_record.py", line 78, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2336, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2332, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2415, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2461, in makefile
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/libmodlr.dylib'
2025-05-03 20:13:40,146 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:40,220 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.xml'
2025-05-03 20:13:40,221 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:40,221 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:40,221 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:40,221 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:40,222 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel.so: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel.so'... IGNORING
2025-05-03 20:13:40,222 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/CAMXLayer10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/CAMXLayer10.dylib'... IGNORING
2025-05-03 20:13:40,222 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/CAMXLayer10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/CAMXLayer10.xml'... IGNORING
2025-05-03 20:13:40,222 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Configuration/CAM360.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Configuration/CAM360.xml'... IGNORING
2025-05-03 20:13:40,223 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/customstrategy/metaparameters.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/customstrategy/metaparameters.json'... IGNORING
2025-05-03 20:13:40,223 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/gfxtheme/gfxtheme.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/gfxtheme/gfxtheme.json'... IGNORING
2025-05-03 20:13:40,224 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:40,224 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:40,224 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Cutting Tools (Inch).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Cutting Tools (Inch).json'... IGNORING
2025-05-03 20:13:40,224 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:40,224 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Cutting Tools (Metric).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Cutting Tools (Metric).json'... IGNORING
2025-05-03 20:13:40,226 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Depositing Tools.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Depositing Tools.json'... IGNORING
2025-05-03 20:13:40,227 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Holders (Inch).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Holders (Inch).json'... IGNORING
2025-05-03 20:13:40,227 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Holders (Metric).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Holders (Metric).json'... IGNORING
2025-05-03 20:13:40,228 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Holders - Standard Taper Blanks.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Holders - Standard Taper Blanks.json'... IGNORING
2025-05-03 20:13:40,228 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Hole Making Tools (Inch).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Hole Making Tools (Inch).json'... IGNORING
2025-05-03 20:13:40,229 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Hole Making Tools (Metric).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Hole Making Tools (Metric).json'... IGNORING
2025-05-03 20:13:40,229 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Milling Tools (Inch).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Milling Tools (Inch).json'... IGNORING
2025-05-03 20:13:40,229 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Milling Tools (Metric).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Milling Tools (Metric).json'... IGNORING
2025-05-03 20:13:40,230 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Probes.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Probes.json'... IGNORING
2025-05-03 20:13:40,230 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Turning Tools (Inch).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Turning Tools (Inch).json'... IGNORING
2025-05-03 20:13:40,230 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Turning Tools (Metric).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Turning Tools (Metric).json'... IGNORING
2025-05-03 20:13:40,230 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Tutorial Tools (Inch).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Tutorial Tools (Inch).json'... IGNORING
2025-05-03 20:13:40,231 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Tutorial Tools (Metric).json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/libraries/Samples/Tutorial Tools (Metric).json'... IGNORING
2025-05-03 20:13:40,232 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic DED.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic DED.machine'... IGNORING
2025-05-03 20:13:40,233 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic MPBF.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic MPBF.machine'... IGNORING
2025-05-03 20:13:40,234 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic SLADLP Printer.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic SLADLP Printer.mch'... IGNORING
2025-05-03 20:13:40,234 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic SLADLP Printer.png: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic SLADLP Printer.png'... IGNORING
2025-05-03 20:13:40,234 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic SLS.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/additive_Generic SLS.machine'... IGNORING
2025-05-03 20:13:40,234 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Cincinnati FTV5-1800.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Cincinnati FTV5-1800.machine'... IGNORING
2025-05-03 20:13:40,235 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/DECKEL MAHO - DMF 250.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/DECKEL MAHO - DMF 250.machine'... IGNORING
2025-05-03 20:13:40,235 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/DMU-50.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/DMU-50.machine'... IGNORING
2025-05-03 20:13:40,235 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/DMU-70.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/DMU-70.machine'... IGNORING
2025-05-03 20:13:40,236 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 200.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 200.machine'... IGNORING
2025-05-03 20:13:40,236 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 300.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 300.machine'... IGNORING
2025-05-03 20:13:40,237 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 500.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 500.machine'... IGNORING
2025-05-03 20:13:40,237 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 600.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 600.machine'... IGNORING
2025-05-03 20:13:40,238 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 800 3-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 800 3-axis.machine'... IGNORING
2025-05-03 20:13:40,238 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 800 5-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Exeron HSC 800 5-axis.machine'... IGNORING
2025-05-03 20:13:40,239 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 3-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 3-axis.machine'... IGNORING
2025-05-03 20:13:40,239 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 3-axis.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 3-axis.mch'... IGNORING
2025-05-03 20:13:40,240 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-head).machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-head).machine'... IGNORING
2025-05-03 20:13:40,241 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-head).mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-head).mch'... IGNORING
2025-05-03 20:13:40,242 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-table).machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-table).machine'... IGNORING
2025-05-03 20:13:40,249 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-table).mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (head-table).mch'... IGNORING
2025-05-03 20:13:40,253 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (table-table).machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (table-table).machine'... IGNORING
2025-05-03 20:13:40,254 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (table-table).mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis AC (table-table).mch'... IGNORING
2025-05-03 20:13:40,254 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis BC (head-head).machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis BC (head-head).machine'... IGNORING
2025-05-03 20:13:40,255 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis BC (head-table).machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis BC (head-table).machine'... IGNORING
2025-05-03 20:13:40,267 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis BC (table-table).machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic 5-axis BC (table-table).machine'... IGNORING
2025-05-03 20:13:40,269 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic A-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic A-axis.machine'... IGNORING
2025-05-03 20:13:40,273 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic A-axis.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic A-axis.mch'... IGNORING
2025-05-03 20:13:40,284 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:40,302 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic additive FFF.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic additive FFF.mch'... IGNORING
2025-05-03 20:13:40,304 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic B-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic B-axis.machine'... IGNORING
2025-05-03 20:13:40,304 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic C-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic C-axis.machine'... IGNORING
2025-05-03 20:13:40,306 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Cutting.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Cutting.machine'... IGNORING
2025-05-03 20:13:40,308 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Cutting.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Cutting.mch'... IGNORING
2025-05-03 20:13:40,308 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic dual spindle lathe with live tooling.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic dual spindle lathe with live tooling.mch'... IGNORING
2025-05-03 20:13:40,309 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:40,309 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic dual spindle Y axis lathe with live tooling.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic dual spindle Y axis lathe with live tooling.mch'... IGNORING
2025-05-03 20:13:40,309 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:40,309 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:40,310 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:40,310 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2417, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2446, in makedir
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:40,311 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Inspection.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Inspection.machine'... IGNORING
2025-05-03 20:13:40,311 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Inspection.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Inspection.mch'... IGNORING
2025-05-03 20:13:40,311 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Lathe.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Lathe.machine'... IGNORING
2025-05-03 20:13:40,312 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Lathe.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Lathe.mch'... IGNORING
2025-05-03 20:13:40,312 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Mill-Turn.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Mill-Turn.machine'... IGNORING
2025-05-03 20:13:40,312 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Mill-Turn.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic Mill-Turn.mch'... IGNORING
2025-05-03 20:13:40,313 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic single spindle lathe with live tooling.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic single spindle lathe with live tooling.mch'... IGNORING
2025-05-03 20:13:40,313 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic single spindle Y axis lathe with live tooling.mch: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Generic single spindle Y axis lathe with live tooling.mch'... IGNORING
2025-05-03 20:13:40,314 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/HAAS A-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/HAAS A-axis.machine'... IGNORING
2025-05-03 20:13:40,315 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/HAAS AB-axis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/HAAS AB-axis.machine'... IGNORING
2025-05-03 20:13:40,315 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/HAAS VM-3 TR2105BX.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/HAAS VM-3 TR2105BX.machine'... IGNORING
2025-05-03 20:13:40,316 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Hermle C30U.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Hermle C30U.machine'... IGNORING
2025-05-03 20:13:40,316 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Hermle C800.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Hermle C800.machine'... IGNORING
2025-05-03 20:13:40,317 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/MAZAK Variaxis.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/MAZAK Variaxis.machine'... IGNORING
2025-05-03 20:13:40,317 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Mikron - HSM-400U.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Mikron - HSM-400U.machine'... IGNORING
2025-05-03 20:13:40,317 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Reichenbacher.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Reichenbacher.machine'... IGNORING
2025-05-03 20:13:40,317 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Roland MDX540.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Roland MDX540.machine'... IGNORING
2025-05-03 20:13:40,318 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Thermwood.machine: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/machines/Thermwood.machine'... IGNORING
2025-05-03 20:13:40,318 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/MFGFSS/mfgfssSchema.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/MFGFSS/mfgfssSchema.json'... IGNORING
2025-05-03 20:13:40,318 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/pim/inspectionSchema.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/pim/inspectionSchema.json'... IGNORING
2025-05-03 20:13:40,319 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/pim/pmiSchema.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/pim/pmiSchema.json'... IGNORING
2025-05-03 20:13:40,319 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/acramatic.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/acramatic.cps'... IGNORING
2025-05-03 20:13:40,319 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/acurite millpwr 2.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/acurite millpwr 2.cps'... IGNORING
2025-05-03 20:13:40,320 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/acurite millpwr 3.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/acurite millpwr 3.cps'... IGNORING
2025-05-03 20:13:40,320 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/anderson.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/anderson.cps'... IGNORING
2025-05-03 20:13:40,320 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/andronic.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/andronic.cps'... IGNORING
2025-05-03 20:13:40,321 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/anilam conversational.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/anilam conversational.cps'... IGNORING
2025-05-03 20:13:40,321 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/apt.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/apt.cps'... IGNORING
2025-05-03 20:13:40,321 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/belotti.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/belotti.cps'... IGNORING
2025-05-03 20:13:40,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/biemmepi.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/biemmepi.cps'... IGNORING
2025-05-03 20:13:40,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/bostomatic.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/bostomatic.cps'... IGNORING
2025-05-03 20:13:40,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/boxzy.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/boxzy.cps'... IGNORING
2025-05-03 20:13:40,323 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/bridgeport.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/bridgeport.cps'... IGNORING
2025-05-03 20:13:40,323 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/burny plasma.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/burny plasma.cps'... IGNORING
2025-05-03 20:13:40,323 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/camplete.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/camplete.cps'... IGNORING
2025-05-03 20:13:40,324 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/carbide3d.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/carbide3d.cps'... IGNORING
2025-05-03 20:13:40,325 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/centroid.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/centroid.cps'... IGNORING
2025-05-03 20:13:40,325 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/cncrouterparts.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/cncrouterparts.cps'... IGNORING
2025-05-03 20:13:40,325 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.cz.lang: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.cz.lang'... IGNORING
2025-05-03 20:13:40,326 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.de.lang: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.de.lang'... IGNORING
2025-05-03 20:13:40,326 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.en.lang: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.en.lang'... IGNORING
2025-05-03 20:13:40,327 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/datron mcr.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/datron mcr.cps'... IGNORING
2025-05-03 20:13:40,327 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/denford.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/denford.cps'... IGNORING
2025-05-03 20:13:40,328 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/dialog 112.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/dialog 112.cps'... IGNORING
2025-05-03 20:13:40,328 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/dump.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/dump.cps'... IGNORING
2025-05-03 20:13:40,329 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/dynapath.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/dynapath.cps'... IGNORING
2025-05-03 20:13:40,329 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/eding.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/eding.cps'... IGNORING
2025-05-03 20:13:40,329 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/emc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/emc.cps'... IGNORING
2025-05-03 20:13:40,330 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/eztrak conversational.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/eztrak conversational.cps'... IGNORING
2025-05-03 20:13:40,330 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fadal.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fadal.cps'... IGNORING
2025-05-03 20:13:40,330 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fagor.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fagor.cps'... IGNORING
2025-05-03 20:13:40,331 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc incremental.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc incremental.cps'... IGNORING
2025-05-03 20:13:40,331 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc turning.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc turning.cps'... IGNORING
2025-05-03 20:13:40,331 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/fanuc.cps'... IGNORING
2025-05-03 20:13:40,332 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/flexicam.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/flexicam.cps'... IGNORING
2025-05-03 20:13:40,332 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/generative-machining.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/generative-machining.cps'... IGNORING
2025-05-03 20:13:40,332 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/generic fff machine.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/generic fff machine.cps'... IGNORING
2025-05-03 20:13:40,333 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/gplus.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/gplus.cps'... IGNORING
2025-05-03 20:13:40,333 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/grbl.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/grbl.cps'... IGNORING
2025-05-03 20:13:40,333 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/gskcnc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/gskcnc.cps'... IGNORING
2025-05-03 20:13:40,334 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/haas turning.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/haas turning.cps'... IGNORING
2025-05-03 20:13:40,334 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/haas umc-750.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/haas umc-750.cps'... IGNORING
2025-05-03 20:13:40,334 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/haas.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/haas.cps'... IGNORING
2025-05-03 20:13:40,335 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain 407.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain 407.cps'... IGNORING
2025-05-03 20:13:40,335 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain iso.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain iso.cps'... IGNORING
2025-05-03 20:13:40,335 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain turning.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain turning.cps'... IGNORING
2025-05-03 20:13:40,335 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/heidenhain.cps'... IGNORING
2025-05-03 20:13:40,336 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/hurco.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/hurco.cps'... IGNORING
2025-05-03 20:13:40,336 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/hypertherm jet.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/hypertherm jet.cps'... IGNORING
2025-05-03 20:13:40,336 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/intelitek.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/intelitek.cps'... IGNORING
2025-05-03 20:13:40,336 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/isel.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/isel.cps'... IGNORING
2025-05-03 20:13:40,337 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/jet.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/jet.cps'... IGNORING
2025-05-03 20:13:40,337 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/kosy.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/kosy.cps'... IGNORING
2025-05-03 20:13:40,337 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/linuxcnc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/linuxcnc.cps'... IGNORING
2025-05-03 20:13:40,338 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mach2mill.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mach2mill.cps'... IGNORING
2025-05-03 20:13:40,338 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mach3mill.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mach3mill.cps'... IGNORING
2025-05-03 20:13:40,338 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mazak.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mazak.cps'... IGNORING
2025-05-03 20:13:40,338 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mazatrol fusion640m.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mazatrol fusion640m.cps'... IGNORING
2025-05-03 20:13:40,339 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mektronix.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mektronix.cps'... IGNORING
2025-05-03 20:13:40,339 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/meldas.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/meldas.cps'... IGNORING
2025-05-03 20:13:40,339 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/millplus.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/millplus.cps'... IGNORING
2025-05-03 20:13:40,339 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/milltronics.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/milltronics.cps'... IGNORING
2025-05-03 20:13:40,339 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/minimal.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/minimal.cps'... IGNORING
2025-05-03 20:13:40,340 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mitsubishi.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mitsubishi.cps'... IGNORING
2025-05-03 20:13:40,340 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mori-apt.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mori-apt.cps'... IGNORING
2025-05-03 20:13:40,340 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/multicam hpgl.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/multicam hpgl.cps'... IGNORING
2025-05-03 20:13:40,340 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/multicam.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/multicam.cps'... IGNORING
2025-05-03 20:13:40,341 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mydiycnc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/mydiycnc.cps'... IGNORING
2025-05-03 20:13:40,341 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/num.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/num.cps'... IGNORING
2025-05-03 20:13:40,341 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/okuma.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/okuma.cps'... IGNORING
2025-05-03 20:13:40,342 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/omax.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/omax.cps'... IGNORING
2025-05-03 20:13:40,342 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/operation-sheet-csv.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/operation-sheet-csv.cps'... IGNORING
2025-05-03 20:13:40,342 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/operation-sheet.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/operation-sheet.cps'... IGNORING
2025-05-03 20:13:40,343 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/opticut.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/opticut.cps'... IGNORING
2025-05-03 20:13:40,343 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/osai.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/osai.cps'... IGNORING
2025-05-03 20:13:40,343 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/othermill.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/othermill.cps'... IGNORING
2025-05-03 20:13:40,344 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/pocket nc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/pocket nc.cps'... IGNORING
2025-05-03 20:13:40,344 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/prototrak.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/prototrak.cps'... IGNORING
2025-05-03 20:13:40,344 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/roeders rms6.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/roeders rms6.cps'... IGNORING
2025-05-03 20:13:40,345 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/roland iso.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/roland iso.cps'... IGNORING
2025-05-03 20:13:40,345 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/roland rml.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/roland rml.cps'... IGNORING
2025-05-03 20:13:40,346 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/rs274.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/rs274.cps'... IGNORING
2025-05-03 20:13:40,346 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/scm.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/scm.cps'... IGNORING
2025-05-03 20:13:40,346 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/seicos.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/seicos.cps'... IGNORING
2025-05-03 20:13:40,347 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/selca.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/selca.cps'... IGNORING
2025-05-03 20:13:40,347 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel-2007-template.xlsx: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel-2007-template.xlsx'... IGNORING
2025-05-03 20:13:40,348 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel-2007.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel-2007.cps'... IGNORING
2025-05-03 20:13:40,348 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel-template.xls: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel-template.xls'... IGNORING
2025-05-03 20:13:40,348 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet-excel.cps'... IGNORING
2025-05-03 20:13:40,349 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet.cps'... IGNORING
2025-05-03 20:13:40,349 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet.css: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/setup-sheet.css'... IGNORING
2025-05-03 20:13:40,350 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/shopbot.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/shopbot.cps'... IGNORING
2025-05-03 20:13:40,350 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/siemens turning.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/siemens turning.cps'... IGNORING
2025-05-03 20:13:40,350 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/siemens-802d.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/siemens-802d.cps'... IGNORING
2025-05-03 20:13:40,350 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/siemens-840d.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/siemens-840d.cps'... IGNORING
2025-05-03 20:13:40,351 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/smoothie.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/smoothie.cps'... IGNORING
2025-05-03 20:13:40,351 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tekna.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tekna.cps'... IGNORING
2025-05-03 20:13:40,351 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/thermwood.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/thermwood.cps'... IGNORING
2025-05-03 20:13:40,351 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tinyg.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tinyg.cps'... IGNORING
2025-05-03 20:13:40,352 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tool-sheet-csv.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tool-sheet-csv.cps'... IGNORING
2025-05-03 20:13:40,352 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tool-sheet.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tool-sheet.cps'... IGNORING
2025-05-03 20:13:40,352 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tool-sheet.css: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tool-sheet.css'... IGNORING
2025-05-03 20:13:40,352 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/torchmate.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/torchmate.cps'... IGNORING
2025-05-03 20:13:40,353 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tormach.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/tormach.cps'... IGNORING
2025-05-03 20:13:40,353 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/validating.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/validating.cps'... IGNORING
2025-05-03 20:13:40,353 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/wincnc.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/wincnc.cps'... IGNORING
2025-05-03 20:13:40,353 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/xml.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/xml.cps'... IGNORING
2025-05-03 20:13:40,354 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/yasnac.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Posts/yasnac.cps'... IGNORING
2025-05-03 20:13:40,354 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/postsettingsspec/PostSettingsSpecification.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/postsettingsspec/PostSettingsSpecification.json'... IGNORING
2025-05-03 20:13:40,354 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic DLP.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic DLP.printsetting'... IGNORING
2025-05-03 20:13:40,355 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 10 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 10 micron.printsetting'... IGNORING
2025-05-03 20:13:40,355 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 100 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 100 micron.printsetting'... IGNORING
2025-05-03 20:13:40,355 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 20 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 20 micron.printsetting'... IGNORING
2025-05-03 20:13:40,356 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 200 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 200 micron.printsetting'... IGNORING
2025-05-03 20:13:40,356 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 25 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 25 micron.printsetting'... IGNORING
2025-05-03 20:13:40,356 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 30 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 30 micron.printsetting'... IGNORING
2025-05-03 20:13:40,357 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 300 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 300 micron.printsetting'... IGNORING
2025-05-03 20:13:40,357 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 40 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 40 micron.printsetting'... IGNORING
2025-05-03 20:13:40,357 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 50 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 50 micron.printsetting'... IGNORING
2025-05-03 20:13:40,358 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 60 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 60 micron.printsetting'... IGNORING
2025-05-03 20:13:40,358 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 90 micron.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic MPBF 90 micron.printsetting'... IGNORING
2025-05-03 20:13:40,358 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic SLA.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Autodesk Generic SLA.printsetting'... IGNORING
2025-05-03 20:13:40,358 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Generic SLS.printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/Generic SLS.printsetting'... IGNORING
2025-05-03 20:13:40,359 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/PLA (Bowden Tube).printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/PLA (Bowden Tube).printsetting'... IGNORING
2025-05-03 20:13:40,359 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/PLA (Direct Drive).printsetting: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/printsettings/PLA (Direct Drive).printsetting'... IGNORING
2025-05-03 20:13:40,359 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/setupsheet/setup-sheet-JSON.cps: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/setupsheet/setup-sheet-JSON.cps'... IGNORING
2025-05-03 20:13:40,359 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Alloy Steel.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Alloy Steel.json'... IGNORING
2025-05-03 20:13:40,360 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum Alloys.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum Alloys.json'... IGNORING
2025-05-03 20:13:40,360 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum hard.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum hard.json'... IGNORING
2025-05-03 20:13:40,360 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum medium.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum medium.json'... IGNORING
2025-05-03 20:13:40,361 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum soft.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Aluminum soft.json'... IGNORING
2025-05-03 20:13:40,361 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Ceramic.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Ceramic.json'... IGNORING
2025-05-03 20:13:40,361 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Copper Alloys.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Copper Alloys.json'... IGNORING
2025-05-03 20:13:40,361 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Glass.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Glass.json'... IGNORING
2025-05-03 20:13:40,362 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Hardwood.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Hardwood.json'... IGNORING
2025-05-03 20:13:40,362 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Magnesium Alloys.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Magnesium Alloys.json'... IGNORING
2025-05-03 20:13:40,362 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Plastic.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Plastic.json'... IGNORING
2025-05-03 20:13:40,362 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Softwood.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Softwood.json'... IGNORING
2025-05-03 20:13:40,363 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Stainless Steel.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Stainless Steel.json'... IGNORING
2025-05-03 20:13:40,363 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Steel, High-Carbon.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Steel, High-Carbon.json'... IGNORING
2025-05-03 20:13:40,363 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Steel, Low-Carbon.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Steel, Low-Carbon.json'... IGNORING
2025-05-03 20:13:40,363 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Steel, Medium-Carbon.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Steel, Medium-Carbon.json'... IGNORING
2025-05-03 20:13:40,364 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Stone.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Stone.json'... IGNORING
2025-05-03 20:13:40,364 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Titanium Alloys.json: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/stockmaterials/Titanium Alloys.json'... IGNORING
2025-05-03 20:13:40,364 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/arrangements/FFF - Additive Arrange.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/arrangements/FFF - Additive Arrange.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,364 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/arrangements/MJF - Additive Arrange.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/arrangements/MJF - Additive Arrange.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,365 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/arrangements/SLA - Additive Arrange.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/arrangements/SLA - Additive Arrange.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,365 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Countersink Drill Tap.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Countersink Drill Tap.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,365 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Countersink Drill.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Countersink Drill.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,365 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Bore.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Bore.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,366 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Counterbore Bore.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Counterbore Bore.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,366 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Counterbore.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Counterbore.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,366 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Counterdrill.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Counterdrill.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,366 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Ream.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Ream.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,366 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Tap.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill Tap.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,367 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/holes/Spotdrill Drill.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,367 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/orientations/FFF - Automatic Orientation.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/orientations/FFF - Automatic Orientation.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,367 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/orientations/SLA - Automatic Orientation.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/orientations/SLA - Automatic Orientation.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,367 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/FFF - Solid Bar Support with Braces.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/FFF - Solid Bar Support with Braces.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,368 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/FFF - Solid Bar Support.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/FFF - Solid Bar Support.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,368 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/FFF - Solid Volume Supports.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/FFF - Solid Volume Supports.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,368 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/MPBF - Bar and Volume (Surface) supports.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/MPBF - Bar and Volume (Surface) supports.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,368 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/MPBF - Volume (Surface) Support.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/MPBF - Volume (Surface) Support.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,369 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/MPBF - Volume and Bar supports for Stainless Steel.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/MPBF - Volume and Bar supports for Stainless Steel.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,369 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/One Click Metal - Braced Bar Support.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/One Click Metal - Braced Bar Support.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,369 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/One Click Metal - Lattice Support (Constant Shape).f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/One Click Metal - Lattice Support (Constant Shape).f3dhsm-template'... IGNORING
2025-05-03 20:13:40,369 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/One Click Metal - Volume Support.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/One Click Metal - Volume Support.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/SLA - Braced Bar Support.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/SLA - Braced Bar Support.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/SLA - Lattice Support.f3dhsm-template: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/templates/supports/SLA - Lattice Support.f3dhsm-template'... IGNORING
2025-05-03 20:13:40,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/threads/ansi-unified-screw-threads.csv: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/threads/ansi-unified-screw-threads.csv'... IGNORING
2025-05-03 20:13:40,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/threads/iso-metric-profile.csv: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/threads/iso-metric-profile.csv'... IGNORING
2025-05-03 20:13:40,371 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/chinese_cn.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/chinese_cn.xml'... IGNORING
2025-05-03 20:13:40,371 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.chs.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.chs.xml'... IGNORING
2025-05-03 20:13:40,371 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.de.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.de.xml'... IGNORING
2025-05-03 20:13:40,371 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.en.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.en.xml'... IGNORING
2025-05-03 20:13:40,372 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.es.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.es.xml'... IGNORING
2025-05-03 20:13:40,372 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.fr.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.fr.xml'... IGNORING
2025-05-03 20:13:40,373 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.it.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.it.xml'... IGNORING
2025-05-03 20:13:40,373 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.jp.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.jp.xml'... IGNORING
2025-05-03 20:13:40,373 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.kr.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.kr.xml'... IGNORING
2025-05-03 20:13:40,374 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.pl.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.pl.xml'... IGNORING
2025-05-03 20:13:40,374 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.pt.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.pt.xml'... IGNORING
2025-05-03 20:13:40,374 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.tr.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/featureflags.tr.xml'... IGNORING
2025-05-03 20:13:40,375 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/french_fr.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/french_fr.xml'... IGNORING
2025-05-03 20:13:40,375 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/german_de.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/german_de.xml'... IGNORING
2025-05-03 20:13:40,375 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/italian_it.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/italian_it.xml'... IGNORING
2025-05-03 20:13:40,376 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/japanese_jp.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/japanese_jp.xml'... IGNORING
2025-05-03 20:13:40,376 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/korean_kr.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/korean_kr.xml'... IGNORING
2025-05-03 20:13:40,377 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/polish_pl.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/polish_pl.xml'... IGNORING
2025-05-03 20:13:40,378 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/portuguese_pt.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/portuguese_pt.xml'... IGNORING
2025-05-03 20:13:40,378 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/spanish_es.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/spanish_es.xml'... IGNORING
2025-05-03 20:13:40,378 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/turkish_tr.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/Data/Translations/turkish_tr.xml'... IGNORING
2025-05-03 20:13:40,378 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/dcamcomponents.so: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/dcamcomponents.so'... IGNORING
2025-05-03 20:13:40,379 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/IronCustomKernelReference: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/IronCustomKernelReference'... IGNORING
2025-05-03 20:13:40,379 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libADFlowPluginInterface.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libADFlowPluginInterface.dylib'... IGNORING
2025-05-03 20:13:40,380 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_buildstyle_proc.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_buildstyle_proc.dylib'... IGNORING
2025-05-03 20:13:40,380 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_ebpa_pproc.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_ebpa_pproc.dylib'... IGNORING
2025-05-03 20:13:40,381 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_polygon_tools.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_polygon_tools.dylib'... IGNORING
2025-05-03 20:13:40,381 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_slice_rep.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_slice_rep.dylib'... IGNORING
2025-05-03 20:13:40,382 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_smoke_sim.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_smoke_sim.dylib'... IGNORING
2025-05-03 20:13:40,382 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_tp_exporter.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libatu_tp_exporter.dylib'... IGNORING
2025-05-03 20:13:40,382 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libcompmetrology.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libcompmetrology.dylib'... IGNORING
2025-05-03 20:13:40,383 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libInfillPlugin.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libInfillPlugin.dylib'... IGNORING
2025-05-03 20:13:40,383 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronAdditive10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronAdditive10.dylib'... IGNORING
2025-05-03 20:13:40,384 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronCommonUI10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronCommonUI10.dylib'... IGNORING
2025-05-03 20:13:40,384 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronCore10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronCore10.dylib'... IGNORING
2025-05-03 20:13:40,385 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronGeometry10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronGeometry10.dylib'... IGNORING
2025-05-03 20:13:40,385 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronMachine10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronMachine10.dylib'... IGNORING
2025-05-03 20:13:40,385 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronNC10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronNC10.dylib'... IGNORING
2025-05-03 20:13:40,385 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronParser10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronParser10.dylib'... IGNORING
2025-05-03 20:13:40,386 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronTool10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronTool10.dylib'... IGNORING
2025-05-03 20:13:40,386 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronToolImport10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronToolImport10.dylib'... IGNORING
2025-05-03 20:13:40,386 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronToolLibrary10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronToolLibrary10.dylib'... IGNORING
2025-05-03 20:13:40,386 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronUtils10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libIronUtils10.dylib'... IGNORING
2025-05-03 20:13:40,387 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libmozjs-128.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libmozjs-128.dylib'... IGNORING
2025-05-03 20:13:40,387 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libmwgeolib.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libmwgeolib.dylib'... IGNORING
2025-05-03 20:13:40,387 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libnetfabbcore4.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libnetfabbcore4.dylib'... IGNORING
2025-05-03 20:13:40,387 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libnetfabbpostprocessors.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libnetfabbpostprocessors.dylib'... IGNORING
2025-05-03 20:13:40,387 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libPanAdaptor.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libPanAdaptor.dylib'... IGNORING
2025-05-03 20:13:40,388 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libStandardNodes.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libStandardNodes.dylib'... IGNORING
2025-05-03 20:13:40,388 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libsupportkernel.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libsupportkernel.dylib'... IGNORING
2025-05-03 20:13:40,388 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libToolpathPluginTypes.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libToolpathPluginTypes.dylib'... IGNORING
2025-05-03 20:13:40,388 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/LibTorpedo.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/LibTorpedo.dylib'... IGNORING
2025-05-03 20:13:40,389 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libTorpedoNodesPlugin.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libTorpedoNodesPlugin.dylib'... IGNORING
2025-05-03 20:13:40,389 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libvoxel_nesting.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/libvoxel_nesting.dylib'... IGNORING
2025-05-03 20:13:40,389 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/CAMFunctions.py: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/CAMFunctions.py'... IGNORING
2025-05-03 20:13:40,389 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Bold Italic.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Bold Italic.woff2'... IGNORING
2025-05-03 20:13:40,390 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Bold.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Bold.woff2'... IGNORING
2025-05-03 20:13:40,390 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Italic.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Italic.woff2'... IGNORING
2025-05-03 20:13:40,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Regular.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Regular.woff2'... IGNORING
2025-05-03 20:13:40,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Semi Bold Italic.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Semi Bold Italic.woff2'... IGNORING
2025-05-03 20:13:40,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Semi Bold.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Element Semi Bold.woff2'... IGNORING
2025-05-03 20:13:40,391 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Legend Black Italic.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Legend Black Italic.woff2'... IGNORING
2025-05-03 20:13:40,392 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Legend Extra Bold.woff2: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Artifakt Legend Extra Bold.woff2'... IGNORING
2025-05-03 20:13:40,392 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/error.svg: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/error.svg'... IGNORING
2025-05-03 20:13:40,392 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/error_state_icon.svg: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/error_state_icon.svg'... IGNORING
2025-05-03 20:13:40,393 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/grey_profile_picture_32.svg: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/grey_profile_picture_32.svg'... IGNORING
2025-05-03 20:13:40,393 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Profile_picture_24.svg: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Profile_picture_24.svg'... IGNORING
2025-05-03 20:13:40,393 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Profile_picture_32.svg: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/Profile_picture_32.svg'... IGNORING
2025-05-03 20:13:40,394 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/purify.min.js: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/lib/purify.min.js'... IGNORING
2025-05-03 20:13:40,394 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/ManufacturingAdvisor.html: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/ManufacturingAdvisor.html'... IGNORING
2025-05-03 20:13:40,395 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/progress-ring.gif: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/ManufacturingAdvisor/progress-ring.gif'... IGNORING
2025-05-03 20:13:40,407 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/mwkernel.so: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/mwkernel.so'... IGNORING
2025-05-03 20:13:40,409 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/mwSupport.lic: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/mwSupport.lic'... IGNORING
2025-05-03 20:13:40,409 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilder10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilder10.dylib'... IGNORING
2025-05-03 20:13:40,410 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilder10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilder10.xml'... IGNORING
2025-05-03 20:13:40,410 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilderUI10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilderUI10.dylib'... IGNORING
2025-05-03 20:13:40,410 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilderUI10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilderUI10.xml'... IGNORING
2025-05-03 20:13:40,411 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAM10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAM10.dylib'... IGNORING
2025-05-03 20:13:40,411 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAM10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAM10.xml'... IGNORING
2025-05-03 20:13:40,411 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.dylib: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.dylib'... IGNORING
2025-05-03 20:13:40,411 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.xml
2025-05-03 20:13:40,412 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 123, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 372, in <lambda>
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 673, in _extractpackage
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2269, in extractall
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/tar_package_record.py", line 78, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2336, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2332, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2415, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2461, in makefile
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/NaNeuCAMUI10.xml'
2025-05-03 20:13:40,497 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:40,500 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:40,501 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:40,501 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:40,501 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:40,501 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:40,501 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:40,502 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:40,502 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:41,153 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:41,304 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:41,304 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:41,304 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:41,447 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:41,520 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:41,521 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:41,521 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:41,546 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:41,562 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:41,563 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:41,563 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:41,563 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:41,563 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:41,563 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:41,564 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:41,565 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:41,628 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:41,698 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:41,702 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:41,702 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:41,702 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:41,702 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:41,702 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2417, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2446, in makedir
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:41,710 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:41,710 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:41,710 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:41,847 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:41,885 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:41,888 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:41,889 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:41,889 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:41,889 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:41,889 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:41,889 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:41,890 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:41,890 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:41,919 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:41,919 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:41,919 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:42,195 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:42,199 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:42,199 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:42,200 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:42,200 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:42,200 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:42,200 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:42,200 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:42,201 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:42,761 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:42,790 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:42,856 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:42,857 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:42,857 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:42,871 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:42,871 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:42,871 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:43,118 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:43,118 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:43,126 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:43,126 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:43,126 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:43,127 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:43,127 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:43,127 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:43,127 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:43,127 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:43,128 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:43,128 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:43,129 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:43,129 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:43,129 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:43,158 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:43,223 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:43,223 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:43,224 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:43,401 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:43,404 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:43,404 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:43,405 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:43,405 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:43,405 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:43,405 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:43,405 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:43,407 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:43,578 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:43,684 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:43,684 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:43,684 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:43,857 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:43,861 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:43,861 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:43,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:43,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:43,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:43,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:43,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:43,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:44,226 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:44,240 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:44,305 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:44,305 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:44,306 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:44,320 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:44,320 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:44,320 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:44,483 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:44,486 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:44,487 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:44,487 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:44,487 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:44,487 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:44,498 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:44,504 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:44,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:44,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:44,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:44,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:44,505 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:44,506 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:44,506 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:45,344 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:45,421 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:45,421 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:45,421 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:45,595 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:45,599 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:45,600 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:45,600 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:45,600 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:45,600 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:45,600 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:45,601 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:45,601 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:45,641 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:45,718 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:45,718 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:45,718 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:45,739 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:45,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:45,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:45,862 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:45,904 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:45,908 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:45,909 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:45,909 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:45,909 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:45,909 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:46,045 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:46,050 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:46,050 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:46,051 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:46,051 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:46,051 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:46,051 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:46,051 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:46,052 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:46,330 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:46,414 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:46,414 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:46,414 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:46,596 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:46,602 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:46,602 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:46,602 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:46,602 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:46,603 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:46,603 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:46,603 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:46,603 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:47,108 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:47,169 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:47,169 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:47,169 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:47,438 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:47,447 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:47,447 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:47,447 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:47,447 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:47,448 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:47,448 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:47,448 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:47,448 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:47,714 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:47,778 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:47,778 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:47,778 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:47,935 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:47,954 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:47,960 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:47,960 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:47,960 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:47,961 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:47,961 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:47,961 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:48,003 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:48,003 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:48,003 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:48,031 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:48,031 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:48,031 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:48,316 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:48,322 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:48,323 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:48,323 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:48,323 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:48,323 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:48,323 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:48,324 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:48,324 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 123, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 372, in <lambda>
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 673, in _extractpackage
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2269, in extractall
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/tar_package_record.py", line 78, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2336, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2332, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2415, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2461, in makefile
2025-05-03 20:13:48,363 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:48,369 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:48,369 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:48,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:48,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:48,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:48,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:48,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:48,370 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:48,825 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:48,882 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:48,882 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:48,882 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:49,063 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:49,066 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:49,066 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:49,066 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:49,067 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:49,067 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:49,068 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:49,068 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:49,068 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:49,080 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:49,162 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:49,162 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:49,163 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:49,411 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:49,414 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:49,415 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:49,415 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:49,415 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:49,415 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2417, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2446, in makedir
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:49,632 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:49,708 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:49,708 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:49,708 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:49,980 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:49,985 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:49,986 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:49,986 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:49,986 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:49,986 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:49,986 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:49,987 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:49,987 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:50,159 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:50,208 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:50,241 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:50,242 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:50,242 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:50,295 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:50,295 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:50,295 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:50,498 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:50,502 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:50,502 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:50,502 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:50,502 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:50,502 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:50,502 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:50,503 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:50,503 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:50,548 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:50,551 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:50,551 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:50,551 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:50,552 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:50,552 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:50,552 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:50,552 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:50,552 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:51,408 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:51,477 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:51,478 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:51,478 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:51,646 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:51,665 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:51,669 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:51,669 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:51,669 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:51,669 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:51,670 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:51,708 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:51,708 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:51,708 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:51,917 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:51,984 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:51,995 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:51,997 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:51,997 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:51,998 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:51,999 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:51,999 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:52,000 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:52,001 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:52,001 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:52,001 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:52,001 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:52,174 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:52,178 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:52,178 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:52,179 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:52,179 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:52,179 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:52,179 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:52,179 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:52,180 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:52,466 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:52,549 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:52,549 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:52,549 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:52,723 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:52,726 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:52,727 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:52,727 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:52,727 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:52,727 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:52,727 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:52,728 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:52,728 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:53,410 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:53,478 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:53,478 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:53,478 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:53,523 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:53,525 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:53,621 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:53,621 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:53,621 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:53,625 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:53,625 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:53,625 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:53,733 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:53,737 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:53,737 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:53,737 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:53,738 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:53,738 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:53,798 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:53,800 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:53,805 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist. REMOVING
2025-05-03 20:13:53,805 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist' - IGNORING
2025-05-03 20:13:53,806 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'
2025-05-03 20:13:53,807 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:53,807 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:53,807 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:53,807 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Helpers/AcCoreConsole.app/Contents/Frameworks/AcadDM17.bundle/Contents/Info.plist'... IGNORING
2025-05-03 20:13:53,807 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:53,809 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:53,809 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:53,809 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:53,810 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:53,810 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:53,810 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:53,810 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:53,810 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:54,621 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:54,685 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:54,686 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:54,686 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:54,875 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:54,879 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml. REMOVING
2025-05-03 20:13:54,880 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml' - IGNORING
2025-05-03 20:13:54,880 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'
2025-05-03 20:13:54,880 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Reset action 1 for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:54,880 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:54,880 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:54,880 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Neutron/StringTable/de-DE/InjectionMolding10.xml'... IGNORING
2025-05-03 20:13:54,881 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:54,965 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:55,050 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:55,050 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:55,050 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:55,318 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:55,321 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Trying to extract on top of existing file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel. REMOVING
2025-05-03 20:13:55,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Could not remove /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel' - IGNORING
2025-05-03 20:13:55,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'
2025-05-03 20:13:55,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Reset action 0 for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:55,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2025-05-03 20:13:55,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:55,322 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - WARNING :: Failed to remove cache file /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Libraries/Applications/CAM360/camkernel'... IGNORING
2025-05-03 20:13:55,323 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.retry_algorithm - WARNING :: Problem performing network operation... Trying again.
2025-05-03 20:13:55,572 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/59bdad8a36f73366fe870d50cde3a8af1ffd8197.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:55,647 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:55,647 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:55,648 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:55,686 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/98d484b97078d5d4097019749f3708c4e2765a5f.ta... for package 4871198a6ba06aa6a1281a06577fbbb32267bd93
2025-05-03 20:13:55,771 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:55,772 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:55,772 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:55,836 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:55,839 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.tar_package_record - WARNING :: Failed to extract to /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
2025-05-03 20:13:55,850 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:55,851 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/76e28257321aaa4ee3d3517e00ba71cb87dcad55.ta... for package 15f3e2f221675c40fbfe4ea428b39ff663943393
2025-05-03 20:13:55,916 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:55,916 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:55,916 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:55,950 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:55,951 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:55,951 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9fad504ec7b29f0b09661754f44b516b7ae8d2d3.ta... for package c726ebf44198d6cf8acd81a7e98ae520190d8613
2025-05-03 20:13:56,015 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,015 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,015 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,180 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,180 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,180 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8cec8f255f64aa5e34fb15b0f6a5650b5dfee0c0.ta... for package c726ebf44198d6cf8acd81a7e98ae520190d8613
2025-05-03 20:13:56,253 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,253 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,253 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,287 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,288 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,289 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5a6be9c7143155e2ed086d357b412240aa749147.ta... for package 006592cb04ddbb1ab057271f96032a85c2f73ec4
2025-05-03 20:13:56,356 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,356 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,356 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,429 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,429 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,429 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4e35bb4e24a05cc414c07f1a862957463d6001c3.ta... for package 7b392d5c8680f5d2d7f70bec830e4ced01bdf82a
2025-05-03 20:13:56,452 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/56dc8e8192f272651e7efd9a0a205b1969bd4fdf.ta... for package 646f1c9c5bb09212e0964509c2ff3b7c91205b0c
2025-05-03 20:13:56,528 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,531 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,531 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,542 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,543 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,543 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6a73214095c0c49ba2afde9375fb5a6a4e2aa4b5.ta... for package b32813a03a47f6e54920fd3ffd8403b1ada65cca
2025-05-03 20:13:56,548 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,548 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,549 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,578 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1c2f0eb8d09e797b213f5d5e494bb0be96e9bde.ta... for package 981ef6dc129457d3d92859ab30b9729fb1a315cc
2025-05-03 20:13:56,613 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,613 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,613 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,649 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,649 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,650 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,792 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,793 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,793 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,793 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a52b5dc1ddb88e1cbbe36656ccc459574aaaba7c.ta... for package 563f8dce65c31ab341889ecebd86af04b483b14b
2025-05-03 20:13:56,794 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,794 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7cb755adb4a6621b36f18d0009aeca8bf912c085.ta... for package 563f8dce65c31ab341889ecebd86af04b483b14b
2025-05-03 20:13:56,865 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,865 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,865 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,867 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,867 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,867 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1f1c1caf9c950413e0f234f1dc0a8d604e9365e2.ta... for package dd13ccd9b94b67fc5ece59b9649ca70aa7c0b654
2025-05-03 20:13:56,868 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,868 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,868 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,900 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:56,901 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:56,901 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/bc31b86aa5ea487aed580d803b318dc21806de22.ta... for package 3153506da2dc493886dedf91d78a970f157b197d
2025-05-03 20:13:56,938 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,938 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,938 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:56,966 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:56,966 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:56,966 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,045 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,046 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,046 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b906e23ec066eec1653781787945e96d10fd46a2.ta... for package 0c01ea96df0691578f50bffa06aebd3ec0c7b84c
2025-05-03 20:13:57,059 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,059 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,060 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/169a14445afdda851869f9251d85d08294e2a371.ta... for package 3c934ed86c70159cd892944fb653b94455add6f4
2025-05-03 20:13:57,162 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:57,162 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:57,162 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,190 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:57,191 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:57,191 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,225 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,225 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,226 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,226 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,226 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/142e5db0668c04892ea8bdc8a4d8786b1a88e9bc.ta... for package 3c934ed86c70159cd892944fb653b94455add6f4
2025-05-03 20:13:57,226 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4b98181ca176dd0f11c873d0e59f6785673ca39c.ta... for package be5bee1479dcd831b1c6872f8ad8230ea5bbe35b
2025-05-03 20:13:57,308 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:57,309 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:57,309 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:57,309 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:57,309 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,309 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,396 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,397 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,397 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9f3f5f3613f6872148a1425c4034be652480a277.ta... for package be5bee1479dcd831b1c6872f8ad8230ea5bbe35b
2025-05-03 20:13:57,413 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,413 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,413 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9c24dbc78f2d5595693e063ea8e29ec63965627d.ta... for package be5bee1479dcd831b1c6872f8ad8230ea5bbe35b
2025-05-03 20:13:57,476 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:57,476 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:57,476 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,480 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,481 - MainProcess(79128) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,485 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,486 - MainProcess(79128) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,493 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2025-05-03 20:13:57,493 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2025-05-03 20:13:57,493 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2025-05-03 20:13:57,750 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,751 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa
2025-05-03 20:13:57,751 - MainProcess(79128) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:13:57,751 - MainProcess(79128) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - ERROR :: Non patched update. Raise exception
2025-05-03 20:14:12,022 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action c1d5a6c7dcbf4562b683600beeae3d5f(REMOVE_TEMP_MATERIAL_FOLDER) was not in registry
2025-05-03 20:14:12,022 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 767b2bd85d838756f62ab0fe585baf2227b0e50c
2025-05-03 20:14:12,023 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 767b2bd85d838756f62ab0fe585baf2227b0e50c
2025-05-03 20:14:12,165 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8fcf2264616ba7608829493ee2f82fec1fbebaa0
2025-05-03 20:14:12,170 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6fb4c70b5f81c6dbef865e2801d7e40b6f90fa96
2025-05-03 20:14:12,453 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for d385431040c07681bc9db2f815fa72f301e9639a
2025-05-03 20:14:12,459 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f7afb6077caddec727bb0adfa0880c255977711c
2025-05-03 20:14:12,467 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9d71e6b67c797a251eaf28c70411f4c25a86b009
2025-05-03 20:14:12,500 - MainProcess(79128) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 649c3fca1563c4dc3ce54b25526e5bfcae0dc073
2025-05-03 20:14:12,551 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2025-05-03 20:14:12,553 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NTkuMTUxLjEzOS4yMTA=
2025-05-03 20:14:12,561 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTI3LjAuMC4x
2025-05-03 20:14:12,704 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOgkJMTY4LjEyNi42My4xLCBBZGRyZXNzOgkxNjguMTI2LjYzLjEjNTM=
2025-05-03 20:14:12,705 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2025-05-03 20:14:12,705 - MainProcess(79128) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 123, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 372, in <lambda>
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 673, in _extractpackage
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2269, in extractall
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/tar_package_record.py", line 78, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2336, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2332, in _extract_one
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2417, in _extract_member
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/tarfile.py", line 2446, in makedir
PermissionError: [Errno 1] Operation not permitted: '/Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework'
During handling of the above exception, another exception occurred:
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1176, in execute
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/deploy_process.py", line 106, in execute_without_errorhandling
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1106, in execute_without_errorhandling
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 918, in _config_app
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1894, in _do_installation
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1655, in wait_threads
File "/Users/Shared/Jenkins/3P/PYTHON/3.12.4/mac64_universal2_double_framework_a/Python.framework/Versions/3.12/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/process/process.py", line 1681, in execute_action
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/retry_algorithm.py", line 155, in __call__
File "/Users/Shared/Jenkins/Fusion/Streamer/src/adsk/dls/streamer/utils.py", line 855, in __call__
adsk.dls.streamer.exceptions.PermissionDeniedException: Permission denied: File /Users/yuttong/Library/Application Support/Autodesk/webdeploy/production/e70c239bb1d26fec5aba0c1faee6762025157baa/Autodesk Fusion.app/Contents/Frameworks/ElectronControlsPlugin.framework is in use.
Replies (0)
