I've been trying to solve a problem that involves sweeping a shape along a helix. Apparently, from searching these forums, a lot of other people have similar problems. However, there is no generic helix generator available in Fusion 360, only a coil generator, which generates a body, not a line.
A helix line generator seems like a trivial thing to add, since it must already exist for for the coil generator! Just bring it out to the user interface. This would be most useful for things like spiral tracks for locking lugs and partial threads that don't follow a standard thread type.
Also, if I might make a request: the coil generator (and presumably the line generator behind it) allows many ways of specifying a helix . What would be useful is if one could specify a helix using an axis and two points (each the same distance from the axis, of course) that the helix must go through.
