Having difficulties uninstalling the application.
jbmw
jbmw
Community Visitor
Community Visitor
Log file is attached. It says that there is stuff running hence it cannot uninstall it... but I am pretty positive there is not.
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @jbmw, thanks for posting.
First, make sure in Task Manager that all applications related to Fusion 360 are disabled. By this I mean: Fusion360.exe, adexmtsv.exe (which is mentioned in the logs you provided), and AdCefWebBrowser.exe. For Windows 10 you may need to select "more details" to see all open items.
Alternatively, I would try to use the cleaner tool from this article: How to perform an automatic clean uninstall of Autodesk Fusion 360.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
chris_cummingsDT
Can this solution be updated? Clicking the link provided goes to a 404 error
@Rafal.Chlod @jorge garcia
jhackney1972
This webpage should help you out.  If you still want an "automatic" method, the Fusion Service Utility is what you want.
John Hackney, Retired
chris_cummingsDT
Thanks for the quick reply, @jhackney1972 ! I believe the keyboard chord would work if the app got that far, but hangs on Signing In. I did uninstall through Windows, even though that is not ideal. I am re-installing now.
