haas pre-NGC trunnion multi axis rewind bug
Message 1 of 8
I'm using the current posted haas pre-ngc https://cam.autodesk.com/posts/post.php?name=haas%20trunnion  and I keep getting REWIND: Rewind of machine is required for simultaneous multi-axis toolpath and has been disabled when trying to post any continuous code .
Replies (7)
Message 2 of 8
Arun.rs
HI @Anonymous
Thanks for raising your concern via forum.
You can resolve this error by setting the 'performRewinds' variable to true in the post.
Save the file and test the nc code carefully.
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
Message 3 of 8
Hi @Arun.rs  it is ignoring that line , mine is set to true and I'm getting
Error: REWIND: Rewind of machine is required for simultaneous multi-axis toolpath and has been disabled.
Error at line: 2665
Error in operation: 'Contour4'
Failed while processing onLinear5D() for record 8255.
Message 4 of 8
Arun.rs
Hi @Anonymous
Sorry I could not replicate the same error at my end.
Could you please share your model and the .cps file?
File>Export>.F3d save the file and attach the file to this thread.
Regards
Arun.RS
Message 5 of 8
so I made a demo part and it still happens , also I can't use tapered endmills with multi axis tool paths .
thank you
Message 6 of 8
Arun.rs
HI @Anonymous
Thanks for sharing the project and the post .
I got the error message while processing the 'Steep and Shallow1' toolpath.
and the error cleared by setting below condition in post.
var performRewinds = true; // enables the onRewindMachine logic
Hope this helps!
Regards
Arun.RS
Message 7 of 8
@Arun.rs  that was changed with the same results , the trail has expired . so I can't try again and I'm not sure how I feel about the results I've gotten . I did get advice from someone to use the ngc post and that worked but came up with the issue of slow multi axis moves ( the inverse time ratio in the post being wrong ) . Also there was a few paths that using a tapered ball mill would make sense but all I was an arc error with no clear solution found in the forums .
I guess  the only way to get a reply in a timely manner is scheduling a call .
thank you for you reply's
Message 8 of 8
@Arun.rs  with me having to restart fusion a few times to extend the addon for a day , changing that line worked for outputting code but I'm wondering if the slow feed is still there  . before it wasn't so I'm wondering if the file was no reloaded when I thought it was . I'm testing the code shortly
