Guide line on object or body
sam.verdon
Observer Observer
sam.verdon
Observer
Observer
I am working on a hydrofoil front wing and I would like to give a bit of a curve to my wing.
Currently, the wing is straight but I would like to give it the curve that I have drawn in light blue. I have not found a solution to do it with my basic knowledge skill. If someone knows how to do it I would appreciate having your help 🙂
Thank you
Sam
davebYYPCU
Look like the original body was Sweep with Guide Rail.
You need a parallel trailing edge curve with the new leading edge.
Sweep with Guide Rail, on the two new curves.
Might help....
sam.verdon
Observer
Observer
yes exactly I used the sweep tool with a guide line but I cannot have this profil with this form along hte light blue line..:(
jhackney1972
Could you please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
davebYYPCU
See if this makes sense, (an old file / workflow)
Top / plan view sketch is combined with front view sketch for the bend,
using Project > Intersect curves, but I don't use this set setup anymore, would use a trimmed surface.
Might help....
sam.verdon
Observer
Observer
Thank you everybody for your answer, I still work on the project but I have not time to finish it today. I will post the result when I have finished. For now I will go with the @davebYYPCU gave me 😃
