Grid and model not displaying after last update
rafaelpradosantos
Message 1 of 11
rafaelpradosantos
Hello everybody.
Since the last update (05/08), Fusion isn't showing the grid and any model I load, the weird thing is that when I pass the mouse cursor it shows the faces of my model.
I tried updating my GPU, uninstalled/installed the software and nothing seems to work.
Thank you in advance.
Replies (10)
Message 2 of 11
chance_hogelie
Im having the exact same issue this morning. Worked great last night then woke up to this problem. I also reinstalled the program as well
Message 3 of 11
g-andresen
did you use the Service Utility?
günther
günther
Message 4 of 11
rafaelpradosantos
Hi.
Yes, I used all the options available on the Service Utility, none of them had affect.
Message 5 of 11
chance_hogelie
I did the same and used the available options. Still no change on my end.
Reinstalled it a 2nd time as well still nothing.
Message 6 of 11
bkliment
Same Problem, switched to DirectX 11 from OpenGl and seem to work now.
Message 7 of 11
chance_hogelie
It worked! Thank you!!!
Message 8 of 11
rafaelpradosantos
It worked. Thank you.
Message 9 of 11
karina.harper
Autodesk Support
Autodesk Support
Hi all,
@bkliment found the workaround above. I just wanted to let you know we are aware and are tracking this internally as FUS-110588.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion
What's New in Fusion | Contact Support | EDU Support | Support Board Best Practices
Message 10 of 11
kailee
Same issue here. Quadro P5000, just loaded newest drivers to check if this helped (it didn't).
Only switching to DirectX [9,11] helps. Would be good if we get a fix for this.
Message 11 of 11
bkliment
Agree, I'm just occasional user, hate to see a nice graphics card go underutilized.   I have a P4000 and the latest driver did not help for me as well.
