Graphics issues. Screen flickers and content dissapears
I'm having serious issues with my fusion 360 install on my MSI Bravo 17.
I've linked a screenshow and a small video showing the issues...
Screenshot: https://www.dropbox.com/s/u4jgx78kh24m4dn/Sk%C3%A6rmbillede%202021-08-12%20123856.png?dl=0
Video: https://www.dropbox.com/s/79n0t74lusewk2i/2021-08-12%2013.34.08.mp4?dl=0
It seams that whenever i'm clicking something or doing just about anything this happens.
The screenshot and video are from a completely fresh install on a freshly formatted computer. I've installed the lates drivers and installed Fusion, so no other software have been installed on the machine prior to this...
CPU: Ryzen 5 4600H with Radeon Graphics
APU: Radeon Graphics
GPU: Radeon RX 5500M
Windows 10 Home 64-bit Version 20H2
My system have 16GB of memory and 512MB dedicated to the APU.
Any help or suggestions would be much appreciated
best regards
Jesper
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @Anonymous thanks for posting.
In this issue make sure that Fusion 360 is using dedicated graphics card, not the integrated one. Check the attached screenshot:
You can follow the steps from this article to use high performance graphics.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
I have followed the instructions and the problem persists.
When checking with the diagnostics, it tells me that Fusion is using the RX 5500M as GPU device.
What else can i try?
Best Regards
Jesper
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @Anonymous, thanks for an update.
You can also check your Graphics driver setting in Preferences (click your initials icon in top-right corner). Try all the options and check if one of them will solve the issue.
Sometimes display issues may be caused by using docking station but from your video I assume that you are unlikely to use one.
Rafał Chłód
Hi again.
I have tried to change directX drivers and forced the system to use GPU power, both without any luck.
Then I tried the solution from this post:
https://forums.autodesk.com/t5/fusion-360-support/someone-please-explain-this-i-cannot-see-any-of-th...
And added the environment variables. That did the trick. I have no idea what those do, but I can now use Fusion without any issues.
But thanks for your replies and your suggestions.
Best regards
Jesper
