Global parameters across multiple files in a design?
Analias
Analias
I have a design that has multiple files with components that are referenced by other files. When I add a design parameter to a file, it appears to only apply to that file and the components defined in it. Is there a way to have a "Global" parameters defined that all the files in a design can use?
-Freeman
jhackney1972
Take a look at this blog article and video and see if it fits your situation.
John Hackney, Retired
Analias
John you my favorite person today. That was exactly what I have been needing for the longest time with many of my designs.
One hundred kudos to you.
-Freeman
jhackney1972
If this solved your issue please press the Accept Solution icon to allow others to find the solution to a similar need.  Thanks
